avatar_NARSES2
Assuming the model's fuselage is split symmetrically then it should be filled and rescribed offset.
Which would be fun.
On my current 109 build I just sanded the seam smooth and then scribed down the middle.  On my previous 109 builds I did't bother with it.
I don't spend to much time with panel lines, work on the basis of "stand 72 feet away"  ;) I'm also useless at re-scribing and have come to accept it.
Another thing about 109s - the vertical panel lines are engraved when they should be raised as the real thing had overlapping panels that assisted airflow.
"Visit Scarfolk today!"
Looking at pics of 109s on the interweb and the only one where you can see any panel lines is one that has been stripped for painting.
Yup are was looking at some photos of the internals on the production line and my first thoughts were on how shiny the aluminium was. I'd expected it to be dull. Mind you I suppose it was an alloy rather than Al ?
No real progress. Eye's been giving me a little "gip". Mind you it's a physiological rather than "actual" thing and the specialist says my brain will eventually come around to the situation  :unsure:
Quote from: NARSES2 on August 05, 2019, 05:55:09 AM
The shininess, or not, has more to do with production methods and desired finish rather than alloy.
Highly polished rolls will give the brightest finish. I have various sheets of aluminum of various
thicknesses and alloys; two are the same alloy but different thicknesses, one bright, one dull.
I have a piece of 1/8th plate that has a brushed finish etc.
Quote from: The Wooksta! on August 04, 2019, 06:56:14 AM
Lapped panels do create slightly less drag, but that's not why that method of fabrication is used,
it's used because it's quick, simple and strong.
Quote from: joncarrfarrelly on August 05, 2019, 03:16:22 PM
Ah. So very similar to the various methods used to produced cold rolled sheet and strip then. That I'm more familiar (or was) with
Oddly after typing this my mojo returned and I made some progress on my GB build  :thumbsup:
Quote from: NARSES2 on August 06, 2019, 06:05:33 AM
Exactly the same.
Most of my current efforts are concentrated on my engines more or less GB entry, but some work has been done on the Breda and she's getting very near paint time. I've also resurrected the next kit from the shelf of doom : Airfix A.W. Whitley. This had stalled at the painting stage because I couldn't decide what to finish her as, I have now decided.
And on a completely different note I saw one of our local feral Parakeets this morning. We've a small colony in the woods next door but this is the first one I've seen this summer. Heard them but not seen any until now. Their numbers vary dependent on how bad our winters are.
Radish
Whitley.....PINK? Psychedelic? Would look good with "scales" like on a lizard.... :thumbsup:
Having just finished a "pink" real world Mitchell I think I'll go another way with her - good to see you back mate  :thumbsup:
Quote from: NARSES2 on August 11, 2019, 05:22:22 AM
I have a Mosquito stalled in the stash that will be pink, seems to be a colour that's all the rage at the moment then?
