avatar_TallEng
300 lb Triplex Rocket
Started by TallEng, April 30, 2012, 02:03:03 AM
Quote from: salt6 on April 30, 2012, 08:29:02 PM
Quote from: rickshaw on April 30, 2012, 05:45:58 PM
Calibre measures are invariably taken from land to land across the tube of a barrel (from groove to opposite groove, for laymen).
Lands are the raised portion of the rifling, grooves are the valleys.  You do mean groove to groove?
Really?  And there I have been working on the other assumpation all these years.   :banghead:
Mr.Creak
Quote from: rickshawReally?  And there I have been working on the other assumpation all these years.
Yup.
But it gets worse...
Quote from: rickshawCalibre measures are invariably taken from land to land across the tube of a barrel
Thus:
QuoteIn a rifled barrel, the distance is measured between opposing lands or grooves; groove measurements are common in cartridge designations originating in the United States, while land measurements are more common elsewhere.
Wiki: http://en.wikipedia.org/wiki/Calibre.
I came across much the same problem when "investigating" guns (for my wargame rules). They're listed by calibre and calibre length and I ran into a couple of WWII Russian guns that appeared to have two calibre lengths for exactly the same model number. It turned out that some nations use the grooved portion of the barrel only in such a calculation and others include the length of the chamber. And, being insufferably pedantic thorough, I'd checked as many sources as possible only to find that different sources use different methods.
Ho hum...  :rolleyes:
What if... I had a brain?
Quote from: PR19_Kit on April 30, 2012, 08:12:59 PM
But if you were in the target area would you want to rely on that? I think not, you'd be getting the H**L out of there!  :o
H*!! no! :blink:
That was the whole point of them, like their ground-based equivalents (such as sweet "Katyusha"), they were a terror weapon.
No matter where the d@m^ things were pointed when launched, they could hit almost anywhere! :o
Interestingly there was a 7.2" Burney gun which used a squash head type round. Wonder if they were these rounds or standard 7.2" shells ?
Quote from: NARSES2 on May 01, 2012, 07:57:16 AM
Burney developed his own HESH rounds.  His guns also fired standard HE rounds (which is why he used existing calibres).  The HESH rounds were much longer and less streamlined than the standard HE rounds (and 'cause they had very thin walls, carried considerably more HE filling).
Its taken me a long time to track down the dimensions of the 7.2in HE round.
*Length (less fuze)*   35.07 inches
*Calibre radius head*  5/10
*Body Diameter*        7.185 inches
*Driving Band Diameter*  7.47 inches
*Weight (incl fuze)*    202 lbs
*Explosive Weight*     28 lbs
Go4fun
As a TOW (Tube Launched Opticaly Guided Wire controlled) missile weapon operator in the U. S. Army I can tell you any missile has the ability to go haywire and land anywhere, including on top of the launcher.  :o
When it goes off track and starts climbing, you run! :lol:
Mr.Creak
Current progress:
That nose doesn't look right, but I'm having problems sorting out the CRH geometry.
Any particular scale you want it?
Go4fun
I quote Mr. Creak: "What if... I had a brain?"
I think you do and don't realize the shear magnitude of your WhIffery talents.
Andy
Mr.Creak
Ha!
Many thanks but...
I'm a  design engineer by profession (actually it's a trade - poncy architects draw stuff and THAT'S a "profession" - ho hum  ;D) - what used to be called a draughtsman.
This sort of stuff is workaday for me (although the curves on aircraft are not what I'm used to, simple stuff like this is relatively simple).
It's my intention (ambition?) to work through BSP Hypersonics and Vulcan's Hammer and produce drawings of all the juicy stuff that got (or should have been) hung under wings to go bang.
The good news for anyone wanting copies is that (in true industry manner) I draw them full size and can scale to whatever is required - watch this space.
Requests will be considered - I feel more "urgency" if I'm doing things for other people rather than for my own benefit.
The wonders of AutoCAD and vector line drawings
Mr.Creak
Quote from: Gondor on May 10, 2012, 12:45:28 PM
Wait 'til I get my solid modeller package working.
AutoCAD (in my professional opinion) is a POS.  ;)
