avatar_nönöbär
NöNöBärs's What-If Flugwerft (WIP: Greenland Airforce TS-11 Qinngorneq)
Cobra
Great Work :thumbsup: :thumbsup: :thumbsup: has an Almost 'Thunderbirds' feel to it! Keep up the Great Work :cheers: :cheers: :cheers: Dan
nönöbär
#31
While working on some additional pods for the B-47 APB....
NöNö Bärs Flugwerft has just finished a Junkers Ju 86:
It's an old Italieri kit, build out-of-the-box. Only the decals had to be replaced as the original ones were not usable at all.
It's not really a what-if, but at least the markings are those of a bomber used in Russia in 1942 - when the Ju 86 was not operating as a bomber anymore.
The other plane in the back is an old Frog Do-17 kit.
nönöbär
#33
The B-47 APB is now getting its glossy finish before the decals are added.
The laser & sensor pods are done now, so it should be completed soon.
Sensor pod:
Laser pod:
With those AAMs mounted under the inboard engine pairs, where are you going to put the balancer wheels?
nönöbär
Quote from: PR19_Kit on August 26, 2012, 04:42:14 AM
Hmm, good point... as the kit has no langing gear at all, it seems as if my engeers have missed something..... So the B-47 has to retrun to the Flugwerft again....
Perhaps fold them flat into the wing undersufaces, where there's space? That's what Boeing did with the later B-52.
nönöbär
#37
Now that the B-47 is completed, the next plane is under construction in NöNöBär's Flugwerft:
A Heinkel He280 jet fighter, in a hypothetical Luftwaffe Jagdstaffel in late 1940, early 1941.
The He 280 was the first jet fighter build in Gemrany, flown under jet power about one year before the Me 262.  9 prototypes were build, none of them used operational.
The kit (Huma model)
First parts put together
First color
The He-280 is an excellent subject! I liken it to our (US) later P-59 Aircomet---a competent but not outstanding aircraft. A "starter" jet fighter.
Maybe instead of He-100's as a "propaganda fighter" to fool Allied intelligence....!
I had no idea there was an injection-mold He-280 on the market. I made a He-280 whif long ago from an old resin job, and "lightened" the rear fuselage and tail by using a Vac-form version. I'll share photos of that later, once you are done with yours.
Quote from: sequoiaranger on September 02, 2012, 07:53:56 AM
There probably isn't now, as Huma went bust a few years ago AFAIK. They made some pretty good stuff, mostly German models obviously, and they went together well. I hope someone bought the moulds and will eventually re-pop them.
nönöbär
It's the first Huma model I build, the quality is ok so far. Huma had made several intersting exprimental aircraft and prototypes like the Ju 287, Messerschmitt P1011 the FA 223 and others, but sometimes they are a bit difficult to find.
nönöbär
#41
A little progress o the He 280.
Due to technical problems (airbrush set did not work as it should) and time shortages (boss -> office -> overtime....  :banghead: ) ony the wings are painted with the final camo
Camo looks better on it than the prototype-gray it had in real life.
I don't think I've seen an He 280 in camoflage ? Looking forward to this
nönöbär
#43
Next steps for the He280
Most of the camo painting is done now, and after some little problems, the new airbrush worked ok.
And I learned that I should not spill the color over the airbrush cabin......  :banghead:
That He-280 is looking good! Keep going!
