avatar_nönöbär
NöNöBärs's What-If Flugwerft (WIP: Greenland Airforce TS-11 Qinngorneq)
nönöbär
Quote from: nighthunter on April 24, 2016, 09:45:17 PM
Fun little kit, built one to be destroyed by my 1/144 P-38s, lol!
Did you had a little 1/144 scale Yamamoto on board ? :)
nönöbär
#481
After some delay, the Betty is coming closer to completion. Paint job is done, it is now waiting for the decals.
Ah, and the transparent parts are still missing. Making all the masking is quite a pain in 1/144 scale, as the Betty had very segmented windows. But I am working on this....
nönöbär
#482
To start something new - although I do not know if this will completed at all, but I will try.
So here is what to use (other parts will be required as well):
And this is inside:
So the base model will be the Dornier, with usage of some parts of the A-10.
More to come...
loupgarou
nönöbär
Quote from: loupgarou on June 06, 2016, 02:51:26 PM
Are the black square items computer fans?  :blink:
Yes, this is the part "I do not know if this will completed at all" in my initial post....  ;D
Ooooh, tilt fan?
nönöbär
#486
Everything has to start with something, so we have the interior with the pilots:
The craft will be a two seater only, therefore the backseats will not be added.
Further, all hull windows will be closed, so a putty&sanding is required:
At the back of the plane, the hull is opened on the top, something will be added here.
Oh, the Do 28 + A-10 combination has potential. I have a bash of these also on the project list, but apparently in a different layout than yours.  ;)
Looking forwards to see what becomes of this one!
nönöbär
#488
Some last pics before NöNöBär closes his Flugwerft and starts his summer vacation to Britain.
Crew is now in place:
The GCC D28 needs some propulsion and this is where the A-10 parts join the game:
I now understand where you are going with this  :thumbsup:
Enjoy your vacation.
That's going to be SOME power/weight ratio!  :o
STOL won't be in it, more like VTOL!
nönöbär
#492
Back from Britain, my engineer and I could continue the work on the Skyguard:
Side pods added:
It will later be used for the landing gear and most likely the armament
Rear engine mounts are added:
But still something essential is missing. More next time....
nönöbär
#493
Finally..... Most stuff is now in place:
Fans added to the side of the D28, additional smaller parts added:
Lower side: Landing gear is still missing, the same for armament.
Next will be a visit to the paint shop.
