avatar_ysi_maniac
Is it possible to get ...
Started by ysi_maniac, July 31, 2012, 08:46:49 PM
.... decals with UK flag? I mean the Union Jack, not the roundel.
And flags from other countries?
Thanks
I think I have some from various chopper models thru the years, what are you looking for ?
Aircav
Aeroclub did a set of Union Jack transfers I think, pre WW1.
Sir Sydney Camm
Vertical Airscrew SIG Leader
They're relatively easy to print off in any size you like with an ink-jet or laser printer.
There's isn't an issue with being unable to print white as the whole flag can be printed on white decal paper and then it's a matter of four straight cuts around the edges and you're done.
If you look at some Wargames companies they produce Battle Standards which will include some national flags. A lot of countries either don't exist anymore or have changed their flags but some are still usefull.
Just realised that if you want these for your "Tercio's" build then wargames flags will be ideal because you can get them for the 16th/17th Century Spanish armies
One source is naval decals, you can get a variety of sizes.  They tend to be naval jacks, so not necessarily national flags, although the Union Flag is easy, you just cut it out of the ensigns.  Some of them are waved too, so may or may not be useful.  Another thing that might be useful if you want's to make your own flags is the signal pennants, there's all sorts of colours and styles available.
White Ensign has a good selection:
https://www.whiteensignmodels.com/c/Decals/84/1/
If you need smaller flags, quite a lot of aircraft models have these, especially if they use the national flags as a fin flash, might be worth a look through the model boxes and decals stash.
Depends how mig you want it. This outfit:
http://www.modelflags.com/index.html
do vinyl transfers which I think include flags (work internet won't let me onto the site  :banghead:), but they're sticky vinyl rather than waterslide, so they mightbe a bit thick for very small models.
Off topic, but they also do brilliant little cloth flags to put on flagpoles, masts etc...
I am thinking in covering tail fin of a Hunter, with that decal
About 20 mm x 30 mm
TallEng
Modeldecal did some Hawk decals one of which had the union jack on the fin. It strikes me that the Hawk fin is very Hunterish  ;D perhaps that would do? http://www.hannants.co.uk/product/MD093 should show it.
Keith
Are you doing something similar to G-FFOX?
G-FFOX by pyro-manic, on Flickr
Should actually be fairly simple to mask., especially if you're doing a straight-line version rather than a curvy one.
Nick
Instead of aircraft decals, think temporary tattoos....  http://www.partytattoos.co.uk/  for example.
I used a nice pirate tattoo transfer on a Beriev flying boat some years ago and it's still looking good. I think I varnished it which helped.
