avatar_tc2324
Project Pye
Started by tc2324, October 09, 2012, 02:34:50 PM
tc2324
Forgive me whiffers, for I have sinned. It has been at 3 months since my last kitbash........, so it`s back to the madness......  :party:
This build is for the What If GB over on BM.
Here are the kits.......
..... this is as far as I have got....
..... ok, it`s not very far.  :-\
Now then, whats going where??  :banghead: ;D
Tiger, Tiger!
Martin H
hmm this should be interesting to say the least ;D
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
tc2324
Ok, so I have cut out the bits I needed from the Canberra wings, namely the engines and I`ll now look forward to the hours of sanding down. :banghead:
Here`s a concept picture of the engines in place......
..... and some of you will notice that this looks a lot like the Lanc jet testbed from days of old......
Well this was always going to be the basis for my build, but thats where it now ends and I will be changing areas of the fuselage.
The premise of this design is a pressurised high altitude tactical heavy bomber. (Think Tallboys). ;)
Tiger, Tiger!
Oh I do like the way this is going  :thumbsup:
tc2324
Great looking Lanc Wooksta,  :thumbsup:
There`s only one design aspect both builds will share and it`s coming from the Canberra donor...  ;)
Tiger, Tiger!
Beauty ! Keep it coming !
tc2324
Had a bit of whiffers block on this one as the design and the way this was all going together in my head didn`t seem to work `in the flesh` once I started dry fitting areas together. So the best course of action was to put it down, have a rethink and get a few weird looks from the wife and kids as I sat in the dining room staring at the pieces.  :blink: :lol:
Anyways, I now have a clear path I`m going to follow so the `surgery` has began. :wacko:
As you can see, as less `perspex` is going into this design as possible with both ends being solid. I felt that as this aircraft was going to fly into enemy airspace as high and as fast as possible, defensive weapons would be deleted.
Tiger, Tiger!
Steel Penguin
is that peice above the body going to be used?  it looks alfully like the blue stel bay door for a vulcan to me.  if it is im evan more interested.
Mr.Creak
Quote from: Steel Penguin on October 13, 2012, 07:34:44 AMis that peice above the body going to be used?  it looks alfully like the blue stel bay door for a vulcan to me.
Exactly what I thought.
Presumably:
Quotepressurised high altitude tactical heavy bomber. (Think Tallboys).
This is getting yummier by the minute...
What if... I had a brain?
tc2324
One of the areas that was causing a bit of a drama was how I was going to intergrate the engines into the wings. Well..., I couldn`t. It would have been to risky cutting int the Lanc`s wings for it to go wrong. So as part of the rethink I went for hanging the BAEU`s under the wings on small pylons. Problem solved.
This in turn meant filling the holes in the side of the units so out came a couple of drop tanks from a Hunter and again, job done.
Since the photo was taken, filler has been applied and it will be at least 24 hours before I can go back to work on them.
I also removed the `V` shape fittings for the outer engines on the wings as the positioning of the jets will be midwing.
Tiger, Tiger!
tc2324
Finally got the BAEU`s more or less the shape I want them, just need to attach the pylon`s and add a bit more detail like the odd intake duct here and there, and then they are done and I can start scratch building this aircraft `special` weapon. The engines incorporate parts from a Canberra, Hunter and Meteor so you can`t argue that they are British built...... ;D
Also started on the cockpit section, but to be honest with what I have planned, your really not going to see much of it so this will probably be as far as I go with this.
Tiger, Tiger!
tc2324
So going through the spares box tonight to find two decent solid engine pylons, I came up with zilch.
Then a sprue from the Airfix Vulcan caught my eye. It will need a little bit of re-shapeing, but I think it will work.
The other task tonight was cutting up the Frog Canberra and I somehow have to fit it into the Lanc`s front section. I feel a bit of a headache coming on...... :banghead:
Tiger, Tiger!
Do what I did with the Alston.  Take a piece of balsa sheet, cut it to size and drop in place before sanding it to profile and then cut out the coaming.  Either way, you've a lot of sanding.
tc2324
Quote from: The Wooksta! on October 18, 2012, 04:03:33 AM
Cheers for the tip Wooksta. :thumbsup: Not sure my woodworking skills are up to that so as you can see below, I went with what I know.
A rather `messy` picture of the new cockpit area as I add bits of plastic to rebuild the area so a less filler is used as possible.
Also had to readjust the pilots seat so it was a little higher and a bit more central.
Tiger, Tiger!
