avatar_Taiidantomcat
Lockheed Martin F-35A, B, C and other ideas
Started by Taiidantomcat, November 27, 2012, 01:52:48 PM
Does that piccie prove the F-35 can be flight refuelled, or is it documentary evidence that there are more than two flyable F-35s around?  ;D :lol:
wuzak
Quote from: PR19_Kit on January 23, 2013, 07:22:16 AM
Or that they aren't refuelling - they are being towed!
Quote from: Thorvic on January 28, 2013, 11:51:33 PM
http://www.cybermodeler.com/news/italeri2.shtml
Italeri are finally doing a 1/72 F-35A Lightning II
I hope they got it closer to being right, as opposed to their 'B' version attempt --
Quote from: kitnut617 on January 29, 2013, 06:48:23 AM
That was an X-35B based loosely on the mock-up rather than the actual aircraft in their attempt to be first to market.
Thankfully its not an F-35B this time around as they were originally going to do their nasty trick of adapting the the prototype to resemble a production machine (AV-8B, Typhoon, F-22 etc). However it is Italeri and it could take as long as the real aircraft to be produced in Italy for the model to come out !!!!.
SebastianP
I can already imagine how many Thunderbirds F-35s there'll be when that kit comes out. Fun idea - those of you in the US or Britain, coordinate among you and build different numbers and then display a full team at the Nats/Telford.. :)
I hope that, aside from being reasonably accurate and well fitting, it comes with a full set of external hardpoints, so one can really load for bear. And some nice stores - SDBs, yes please! :D
That's the first RNLAF aircraft. The low-vis roundels are just a gray disk :/
This pre-shading is going TOO far I tell you!  :banghead:
wuzak
Quote from: SebastianP on February 03, 2013, 08:43:28 AM
I always thought that the F-35 was not a very aerobatic aircraft. So, not very good for aerobatics troupes.
Quote from: Hobbes on February 07, 2013, 12:56:51 PM
might become a what-if afterall, i saw a report last week that the Netherlands are concidering the Gripen-E/F and the Superbug due to the rising costs, problems and let-down performance of the F-35  :-\
eatthis
Quote from: rickshaw on January 05, 2013, 06:23:28 PM
Quote from: PR19_Kit on January 05, 2013, 12:41:26 PM
Quote from: Taiidantomcat on January 05, 2013, 06:42:32 AM
Pod and pylons on an F-35B
There goes the 'Stealth' bit anyway.........  :-\
On the second day of a campaign, when all the opposition should have been eliminated, you don't need stealth...  ;D ;D
you dont need the f35 then either lol
http://tinypic.com/m/hx3lmq/3
