avatar_Taiidantomcat
Lockheed Martin F-35A, B, C and other ideas
Started by Taiidantomcat, November 27, 2012, 01:52:48 PM
I thought this was whiff-world, Kit?  Anything is possible!  Just some glue, a razor saw, some spare parts and a lot of PSR and hey, presto!  Liftfans!  ;D ;D ;D
Yes I agree, but where the devil would we put them?
Quote from: PR19_Kit on December 12, 2012, 04:41:19 PM
There were IIRC several projects in the 1960s/70s which featured fold out liftfans for small airliners.  So, under the floor in the fuselage?
wuzak
Why do you need lift fans?
The engine power probably won't be strong enough to lift the aircraft vertically anyway, so add a third jet in the tail with 2d vectoring nozzle. The two wing mounted engines can also have 2d vectoring nozzles, or can be hinged on their mountings and rotate around the leading edge to provide vertical thrust.
lenny100
whell as soon as a 1/144 f-35 in on the market for the nose and some other parts i have a 737 in the stash so i have a go
I thought the Royal Navy was going to go down the V-22 Osprey route for a AEW tilt rotor aircraft, as to the F-35 did the X-32 have the same handling problems?
The Sea Harrier has longer legs than the F-35, have the Indians still got theirs?
Quote from: McColm on December 14, 2012, 02:44:51 AM
Yes.......
Quote from: PR19_Kit on December 12, 2012, 03:21:38 PM
A model of that 737 complete with vectored thrusts exhausts would be pretty awesome. Adding lift fans to it may be a tad more difficult however.....  ;)
Maybe take a 737 and add 727 fin with VT nozzles...? Should look interesting?
Quote from: PR19_Kit on December 14, 2012, 03:42:23 AM
Yes.......
Well, just let the Indians win the cricket and buy back the Sea Harrier from them!!
Quote from: McColm on December 14, 2012, 06:43:27 AM
Yes.......
Trouble is, they are talking about running their Harrier fleet on until at least 2016 and possible 2019.....or so I have gleaned froman Indian website.
The Chinese are good at copying aircraft, have they tried V/STOL?
I'm sure they are trying it. If and when we'll see it is another matter...
Yes.......
NEVER SAH !!!!!! It would mean pistols at dawn
Are there any examples of the Yak-141 around?
You mean scale models? Anigrand and ART Model do them in 1/72.
