What If ideas/goals for the upcoming year, what are YOUR plans?
Started by SigfanUSAF, December 31, 2012, 08:40:25 AM
Quote from: Old Wombat on June 14, 2022, 08:55:45 AM
1. Stay alive!
2. Build models!
In that order. ;)
AGREED!  With a slight amendment
1. Stay alive!  and be able to wish you all a Happy New Year on 01/01/23
2. a      Write more backstories
2.b       Finish some models!
I should be able to kitbash the North American RA-5C with the F-18F. My first thought was to use the conformal fuel tanks on the F-15C/D if they fit.
A swing-wing version using the Mig-23/27.
To finish all my started builds, I still have a few complete kits in the stash but they are big even in 1/72 scale so I will need the room.
I should be working on my 00 gauge layout, finishing my current builds. With the fitness course I will be able to do some of the D.I.Y. jobs like putting up shelves and racking. I might be able to return to work in the spring of 2024.
What if the Boeing B-17 was powered by four Rolls-Royce Griffons? I know that someone tried fitting Rolls-Royce Dart engines back in the 1970s, but I think with the various Shackleton kits available this might be an easier option.
I've always wanted to build the cargo version of the B-17 and a whiffed B-29 freighter.
Somewhere in the stash is a couple of boat kits, I'm not too sure if they are complete or compatible with each other but this should be interesting none the less.
More car builds and a few cheap R/C ready built cars plus a helicopter. I have a park that's very close to me but due to my mobility I haven't been able to visit it yet but once I get my stamina back I'll be out and about more often.
 The 00 gauge layout, this will be built in modules as I keep changing my mind on what it is supposed to look like when it's finished. As to the O gauge one that will run on a continuous loop around my bedroom just below the ceiling on a purpose built shelf.
Well, there was the XB-38, a test bed with four with liquid-cooled Allison V-1710-89 Vee engines:
There are a number of pics of a B-17 with four Darts out there.
Joe C-P
Quote from: McColm on June 15, 2022, 07:00:46 AMWasn't that a song by the Beegees ;D
BG?  Miscellaneous battleship?
I don't know what I'll be doing for what-ifs in the near future.  Maybe I'll hop into the Logistics build; I have an idea, and the base kit isn't expensive.
Boats, something that I haven't had a go at, the Cutty Sark is in Royal Greenwich which is not that far from me and now that I have the room I can display it without it getting broken. Just have to find a bottle big enough for it to fit in  ;D
A large plastic water container will do, cut a piece out so it fits over the top.
Geoff
Quote from: Rheged on June 15, 2022, 08:44:11 AM
Quote from: Old Wombat on June 14, 2022, 08:55:45 AM1. Stay alive!
2. Build models!
In that order. ;)
Yep, sums it up well   :banghead:
Geoff
Ok-
Ultramar war planes, real and wif.
IA-PVO                        ,             ,,
Mig-19's
Su-7's
Migs
Migs
Migs
Starfighters lots and lots
Nihon Kaigun
It looks like the TT 1:120 gauge is almost the same scale as my Hogwarts Castle 3D card puzzle, so I could buy one of the cheaper starter sets and have that as one of my layouts. I just need to find or build a coffee table that's large enough for it all to fit.
Depending on my finances.
Beermonster58
Plans for 2023? Well, I don't normally plan ahead for a year but, my future plans (which may extend beyond 2023 are :
Convair B-58 Hustler (RAF)
B-58C - based (very) loosely on the concept designs
Continuing my line up of aircraft operated by the Air Force of the Independent Scottish Republic including, F-80C/T-33, Breguet Atlantic
A-61 Black Widow - ground attack variant of the P-61
Using the Revell 1/144 TU-95 and, Academy 1/144 B-52, I have a sort of "what if a TU-95 and, B-52 had mated" idea! :blink:  ;D. I propose installing the TU-95 engines on the B-52 wing, using pylon mounts (as in the proposed Boeing XB-55) and, using the B-52 engines likewise on the TU-95. I rather like the bicycle landing gear concept so, I figure it would be possible to modify the TU-95 thus by using the kit main landing gear (subject to suitable modifications)
Airbus A-321 MPA using the excellent Zvezda 1/144 kit
Well, I think that's enough for now!! ;D
Freightdog862
Definitively want to finish some kits! Including my Airfix fabric wing Hurricane which just needs paint....
Thanks,
Colin
Imediate plans are to finnish a build for the currant Group Build and to start on my Double Eagle powered Tempests. Hopefully finnish another couple of builds along the way and I really must make some progress on the Hunters I have started, but we shall see.
