What If ideas/goals for the upcoming year, what are YOUR plans?
Started by SigfanUSAF, December 31, 2012, 08:40:25 AM
Finish the three key builds.  The Silbervogel is done, with the Contrail 390 coming on, only the Hanneubu has stalled.
"Visit Scarfolk today!"
steelpillow
I have three partial whiff builds jostling for attention alongside a couple of (ssh!) real subjects.
My plan is to ... er, um, yes that's it!  ;D
Cheers.
32 builds are waiting for painting and decals, three just need PSR and then they are ready for the next step. Shelf space has been allocated as a temporary measure until the wall racking becomes permanent.
The BAe Systems Tempest looks like a doable kitbash, I think that there's a resin kit available but it hasn't hit the stores in a way that the F-35 or F-22 has.
The Tempest seems to have taken the best parts of some jet fighters and kitbashed them into something new.
I'm guessing the YF-23,  F-105, F-101, F-22 and F-35 depending on what side you're looking at it.
Makes me reach out for the Airfix Lockheed YF-22 Lightning II model kit which comes with the tail and wings separated from the fuselage. There's enough space under the cockpit canopy for a backseat or you can opt for the side-by-side seating if you have a spare F-111 or T.55 Lightning.
The wings do have the F-101 Voodoo look about them with the F-105 air intakes,  the twin tail fins reminded me of the YF-23.
I've built the Airfix YF-22 Lightning II but couldn't get the landing gear to fit but the Airfix F-35B landing gear seems to work.  The YF-22 does lend itself to being cut up for a weapons bay and two fuselage side weapons bays. Which can be tailored made for your missiles and bombs.
Plus the kit is not that expensive.
As the GB season has started I'm leaning towards the Catalina flying boat designs that weren't built or the Sea Hercules. This could have a pair of very large floats former Catalinas fitted under the wings, just need an extension to the rear loading ramp.
Get Ju 390 number three assembled.  I have the bits, but have yet to start looking at the cuts.  The wing is easy enough, the fuselage less so.
Quote from: McColm on May 28, 2024, 08:19:22 AMThe YF-22 does lend itself to being cut up for a weapons bay and two fuselage side weapons bays. Which can be tailored made for your missiles and bombs.
There was a proposal for an FB-22 nuke bomber as sort of an FB-111 replacement. As I recall there was a fuselage extension which provided a bigger bomb bay/missile bay. Also a much larger delta wing.
Quote from: kerick on May 28, 2024, 08:58:51 AMThere was a proposal for an FB-22 nuke bomber as sort of an FB-111 replacement. As I recall there was a fuselage extension which provided a bigger bomb bay/missile bay. Also a much larger delta wing.
Wasn't there one for an FB-23 bomber as well? Even better looking!
seadude
1. Continue working on my 1/350 scale HMS Habakkuk model which will be a multi-year building project.
2. Would like to finish my 1/350 scale USS United States stealth aircraft carrier this year (I hope). This is the main model I want to finish this year.
3. Still have two 1970's Battlestar Galactica models to finish building/painting.
4. A long overdue project which was to convert an LPD-17 San Antonio class amphibious ship into a Clive Cussler type NUMA oceanographic research ship.
5. Hopefully take part in this year's Antarctic Cold War group build and build a TAKOM 1/35 scale Krupp Raumer into an Antarctic snow type vehicle.
6. Build a Testor 1/72 scale B-2 stealth bomber into Santa Clauses's next Christmas present delivery vehicle for a humorous diorama display.
7. Build a V-22 Osprey into a US Navy Antisubmarine variant.
8. Build/convert a Squadron 1/72 scale Haunebu German flying saucer model into a Doctor Who Dalek flying saucer spacecraft model.
9. Build/convert an old 1/72 scale Testor SR-75 Penetrator into a B-3 hypersonic stealth bomber aircraft.
10. Way, way, way down the road on this, but was thinking of converting the very old Revell 1/72 scale B-2 Advanced Technology Bomber kit into a stealthy aerial refueling tanker aircraft.
Quote from: seadude on May 28, 2024, 01:32:13 PM1. Continue working on my 1/350 scale HMS Habakkuk model which will be a multi-year building project.
Good luck with number 10,the wings don't fit and the landing gear needs beefing up.
seadude
Quote from: Beermonster58 on May 29, 2024, 03:24:31 AM
Quote from: McColm on May 29, 2024, 02:41:18 AM
I didn't have any problem with the wings  but, you're right about the undercarriage. I used modified main landing gear from the carcase of a Monogram 1/48 B-58. Even though different scales, the huge size of the SR-75 model means the replacement bits scale in nicely
McColm was refering to #10. Not #9.
I'll repeat, my only goal is to be here to wish everyone a Happy New Year on 1st January 2025
Quote from: Rheged on May 29, 2024, 06:59:50 AMI'll repeat, my only goal is to be here to wish everyone a Happy New Year on 1st January 2025
I'll do my best to be here to return the greeting!
Also need to look at the Hanneubu soon.  Couldn't be bothered with the interior as it's nigh on invisible through the portholes.
