BAe Super Lightning
Started by Snark, February 03, 2013, 02:56:42 PM
Snark
eatthis
great idea apart from the intakes.
the reason they stacked the engines on top of each other was to keep the frontal idea to a minimum.
sticking the intakes on the side ruins this completely.
i think the best thing to do is put the intake under the nose like an f8/a7 thats what i did with mine
a lightning with 44,000 lb thrust? HELL YEAH  :bow: (my whif had a single olympus motor with similer power lol)
http://tinypic.com/m/hx3lmq/3
Snark
Interesting point,
I reasoned that the reconfigured nose can fit a bigger radar and by pushing the intakes as far aft as possible, a lot of internal volume is made available. Also two 'Wye's would require large intakes making a ventral chin inlet a little tricky.
Your souped-up Lightning sounds great- can I see a pic please?
eatthis
i left the intake up front and went for 1 engine to free up loads of internal space so we do think alike lol
Snark
Wired....the nose looks pretty neat but with those intakes it would be 16 feet wide ! I like the Griffon powered Hurricane too.
I like this idea. Both versions look great.
I did a similar chin intake on a modified P.8 Lightning when I first posted here.
Can we see a rear end picture of the single engine?
eatthis
Where does the landing gear go?
eatthis
Quote from: Dizzyfugu on February 05, 2013, 12:56:10 AM
nose gear same as normal maybe a little further back main gear is normal
KJ_Lesnick
Think XF8U-3 nose with an enlarged Lightning wing and like either two J57's or J79's...
Quote from: KJ_Lesnick on February 16, 2013, 04:16:01 PM
Why would you want to replace the Avons? They're more powerful than the J-57 or the J-79.........
KJ_Lesnick
#13
Quote from: PR19_Kit on February 16, 2013, 06:13:15 PMWhy would you want to replace the Avons? They're more powerful than the J-57 or the J-79.........
I'm guessing these are very different than the early RR Avons developed in the late 1940's...
eatthis
Quote from: KJ_Lesnick on February 16, 2013, 07:52:08 PM
what do you mean?
