avatar_Gondor
Gondor's Grumblings
Started by Gondor, April 08, 2013, 11:07:47 AM
Quote from: Gondor on November 25, 2023, 09:24:29 AMAnyway, everything sorted and my mum is happy
That sounds to me like a considerable success!   A happy parent is a GOOD THING
Quote from: Rheged on November 25, 2023, 10:12:23 AMThat sounds to me like a considerable success!   A happy parent is a GOOD THING
Very true. The thing that gets me each time I see her these days is how frail and unable to do as much as she used to be able to do. She put a coat on to go outside to show me what she was wanting on her bin as several of her neighbours use Cable Locks, she got the poppers on the coat out of step so one side was higher than the other and I had to sort it for her as it was easier for me to see and do than it was for her.
Quote from: Gondor on November 25, 2023, 11:37:43 AMshe got the poppers on the coat out of step so one side was higher than the other and I had to sort it for her as it was easier for me to see and do than it was for her.
I'm sure that she did the same for you many times when you were a lad. I know mine did!  ;D
Quote from: The Rat on November 25, 2023, 12:29:53 PM
She probably did, it's that I had to do it for her who always got hers right that hits me. Little things like that really make me realise that she may not be here tomorroe.
Anyway, something more cheerful. I am 100% positive that the missing decals are in my model room. This means thay are within a defined area, unlike the TARDIS which I just watched a recording of. So while checking another area of the room I found....
..... a set of Freightdog Redtop missiles and the under fuselage rack for a Bf 109G
A small win and another part of the room crossed off the possible areas them dastardly decals are hiding
Unless the Monster is having a Laugh and moves them around, just ahead of you...  ;)
Yeah, it always made me stop for a second, when I had to take over doing something for Mum that she'd always done for me before...
I'm going through the same thing with my mom.
Commiserations.  It's not easy, but then you're well aware of that.  :-\
Just keep plugging away. It doesn't necessarily get easier, but you can/do/have to get used to it.
Yesterday I managed to get a little physical modelling done. THe final part of the fuselage of my Hunter T.12 using the Xtrakit T.7 and of course a conversion set by Freightdog. Found out earlier this evening that the rear fuselage parts had moved under the clamps I had used, I had cut one fuselage half in two as I had intended to fit an engine front and intakes but gave up on that idea, so that has been corrected. Might get a bit more work done throughout the week just at the moment I am finding that I am only getting a couple of minuites free to do hands on modelling. Haveing too many ideas of building 1/35 armour and hope to have a couple of items for the Scottish Nationals. That's where a lot of looking up parts, refference material and planning are eating up my time.
As George said, 'Time spent in Reconnaissance is never wasted.'  :thumbsup:
Not much further with anything in the last week. Some filling done on the T.12 Hunter and then some sanding back, that shows that another round of filling is needed, kind of expected though.
I received a new tin of Humbrol Gloss White earlier and have managed to get around to using it today. What a difference! The previous tin was definitely on it's way out as it was producing on off white, the same kind you get with older paint on wood work that yellows over time, the older paint did that as it dried. Anyway, the Vulcan, Buccaneer and Phantom intakes I had previously painted have been done again and after putting the paint away and cleaning the brush I was using I now realise as I type this, I should have painted the Jaguars intakes  :banghead:
Something to do duering the week perhaps.
Looking at the intakes that I painted yesterday once I returned home from work showed that the white is nice and, well white!, which is good news. I still need to paint some parts of the Vulcan intakes as the white is a little thin looking there, but that's ok as it is White!
Painting intakes insides was one of my least favourite pastimes when building V-bombers..  :unsure:
These are the items I am painting so they are seperate to the rest of the wing. The difficulty is not haveing a large enough tub of paint to dip them as cars are or a good set up for using an airbrush.
This set will be fitted into the old Airfix Vulcan which is earmarked for the Indian Air Force.
Quote from: Gondor on December 08, 2023, 06:27:02 AMThis set will be fitted into the old Airfix Vulcan which is earmarked for the Indian Air Force.
Now there's a nice idea. But it reminds me that I still want a Hindustan Marut. Please, Airfix, before I die!
Outside with a can of Halfords and spray down the pipes.  That's what I did with mine.
"Visit Scarfolk today!"
