LCM & sails, red : hybrid aircraft/animals e.a.
Surprising and pleasant, which is the recipe for a great whif model! :thumbsup: ;D
steelpillow
Quote from: kerick on July 25, 2020, 09:40:10 PM
Doesn't the boom and such provide the stability after a certain forward speed and the tail rotor loose it's effectiveness? Some helicopters having more of a "fin" than others perhaps depending on forward speed?
It's more complicated than that. That's the trouble with helicopters, they are devilishly complicated beasts at almost every level. Basically, rotor torque is one problem and aerodynamic stability is another. Mixing the two solutions together is a road to swift perdition.
Cheers.
Quote from: steelpillow on July 26, 2020, 11:17:06 AM
Then Raoul Hafner wondered if you could use the fuselage shape to compensate for torque.  ;D
ericr
ericr
the front engine room for the engine is transformed into a loading door
steelpillow
Very nice! Clearly a STOL heavy-lifter with full-span slotted Fowler flaps. Ideal for lugging around moderate-sized but solid things like power transformers, sandbags or my head. :thumbsup:
Cheers.
ericr
another case of whiffing causing a problem of nose-sitting
(I had to put weight in the rear to avoid it)
