Duck monoplane & He70, yellow : hybrid aircraft/animals e.a.
Another good one. :thumbsup:
Tell me Eric, do you go out with the specific intention of finding something specific for a model or is it a case of seeing something and thinking "oh, that will make a very good helicopter" (for example).
ericr
thanxalot!
sorry for the tail rotor : I reperaired it after the pictures were taken
Quote from: zenrat on October 21, 2016, 02:54:32 PM
well it depends, there is some randomness, or serendipity in the process.
Sometimes I start from an aircraft, sometimes from an object, because I ilke their shape somehow,
and then I think "what could I do with it?"
For example in the case of the bananas, I first bought one fake plastic foam one in order to do this, inspired by a drawing by Kuczynski, which you might remember from there :
http://www.whatifmodellers.com/index.php/topic,37003.msg696592.html#msg696592
and then I saw potentiel for banana fuselages, and then the series took shape (you noticed I like series, maybe?) with monoplanes, biplanes, jet, propeller, ...
And sometimes it the other way round : I bought several space shuttles with boosters (1/144, Academy, real cheap), and then saw what could take the place of the shuttle, or booster, or both ; and a series came out of that (still one or two to go , by the way : stay tuned)
ericr
Quote from: zenrat on October 22, 2016, 03:15:27 AM
Thanks for the explanation Eric.
you are welcome : it is mostly an inspiration thing actually.
Sometimes for particular cases I can say why and how some aspect of the shape of the one and of the other make me see a match, and sometimes I am indeed browsing catalogs for the kit that matches my needs, or conversely.
Someone should whip up a poll containing a number of non-aircraft items. We all vote on the item we want and then Eric gets to build it how he sees fit.   ;D
(I suspected that it was normal "wear and tear" on the rotor, had to bust yer chops a bit!!   ;)   :D  )
ericr
more bananas :
a 1/28 Sopwith Camel (I am busy lowering my stash level ...)
and a banana, because I wanted to see how it could look as a biplane
ericr
the other half of the 1/28 Camel had to have a life, and in my qtash I had this Revell wooden kit of da Vinci designed wings for manned flight :
You are proving Da Vinci was an inventor not a dreamer, or is this the same? ;D
