North American YP-82L Tri-Stang
Started by PR19_Kit, May 02, 2013, 09:39:47 AM
OMG, that's huge! And with 12 machine guns!?
It sure is, quite a bit larger than a B-25!
And yes, it all twelve 0.5s, I figured that was enough, and adding the 8 gun pod on the centre sections would have been overkill.
Lovely.
Looking forward to seeing that contra prop installed on it.
I've done the other two props as well, but once you've seen one prop you've seen 'em all, right?  ;D
They'll appear on the full assembly eventually. Right now I'm summoning up the courage to start scribing in the minimal panel lines, no WAY am I going to do the whole, I'd go daft.
I was surprised how well the silver came out, on two previous NMF aircraft, using the same can, it was a tad blotchy, and looked a bit like newsprint scaled up. Perhaps as the gas pressure drops as the can empties it gives a smoother spray?
Could also be temperature/humidity/tide/phase of the moon related.
MMM
I would have kept the center cockpit, and turned it into a 3-seat trainer- with three sets of active controls, so that one pilot could work with two trainees simultaneously. Imagine how impressive a sight that would be, watching her cartwheel across the sky... ;D
MMM- aka "M3", aka "Major Matt Mason"
Lawrence, KS
Yes, but my backstory has it as an ultra-long range escort fighter with the centre fuselage as a powered fuel tank.
Of course you're free to build one your way as well..............
That's very Bert Rutan-ish, Kit.
And where the hell does everyone get time to play with plastic at the moment?
This bird is coming out beautiful!  :wub: I love the mustang, so i love this 3 times as much!  :bow:
Librarian
Quote from: kitbasher on January 07, 2015, 01:36:25 PM
Seriously bad insomnia :banghead:.
Unemployment  :banghead:
Flyer
#116
Quote from: PR19_Kit on January 07, 2015, 12:25:53 PM
For even longer range you could have the outer fuselages as tanks and a tandem cockpit in the centre...
Looks great kit :thumbsup:
Retirement Dave. I can wholly recommend it.  ;D
Underemployment.  Can't say I recommend it but there are some advantages.
Wow....it does somehow look even bigger with the silver finish ! Looking good. Really good.
