avatar_philp
Whiffs found on Facebook
Started by philp, June 08, 2013, 10:40:54 AM
The VG Phantom lokks really good, and it's close to the respective r/w proposal.
The canard Phantom is rather odd - I also have doubt about launching anything from the underwing station, I'd guess that the foreplanes would be blasted away easily?
Quote from: Dizzyfugu on November 25, 2021, 01:34:12 AM
Move the foreplanes up a bit, make them a fixed* surface with movable control surfaces,
mount the Sidewinder pylons under the foreplane. Sparrows still launch from the belly.
*A fixed surface would be easier to accomplish compared to having to add the gubbins
for an all-moving surface to the intake area.
From Reddit via facebook. This is so sexy it hurts. Facebook being what it is, this link won't last long, grab it while you can.
Caveman
#3048
I saw that too. Crying out to be made. But will take some serious kitbashing/scratch building
edit: had a quick go at simplifying the wing geometry in powerpoint. I think this is what I would go for:
secretprojects forum migrant
Snowtrooper
The simplified version could possibly use F-117 wings and tails (with reduced sweep) as a starting point. (Though, the "complex" main wing could perhaps be made in 1:72 using the whiff-foddery DML/Dragon 1:200 B-2 as a wing donor, or if those are too small, then any one of the numerous 1:144 ones.) The booms would probably have to be a scratchbuild job unless you could scaleorama a pair of 1:144 X-32's to a 1:72 Lightning to get at least the forward part. Unfortunately nobody makes one in 1:144, so using that approach this would have to be built in 1:32 or 1:48, depending on how large the 1:72 X-32 nose would be compared to the engine nacelles.
The original could use the outer wing sections from an 1:200 B-2; Italeri did one, IIRC. But overall this is probably easier carved froma piece of wood than kitbashed and PSRed?
Quote from: Snowtrooper on December 07, 2021, 06:02:50 AM
Uh, I am not sure i understand but I have built many P-38 1/144 from Mini Hobby Models (and there are F-117 1/144 by Revell and Trumpeter, B-2 1/144 by Revell, X-32 1/144 by Triple Nuts according to Google)
Snowtrooper
#3052
I could not find the 1:144 X-32 in Scalemates, but I stand corrected. Others I knew were avaiilable in 1:144. (But the idea is still the same, the X-32 needs to be in a smaller scale than the P-38 starting point, because obviously the X-32 fuselage is humongous compared to the P-38 boom.)
nighthunter
I saw this and did a doubletake then started laughing and crying at work, THANKS!
From one Ian Williams on the Airfix Model Group facebook page. Brilliant!  ;D
There are 2 more pictures on the post, but I can't seem to link to it.
Another member of the  Inverted Sideways Thought Society.   I like it!
CammNut
Quote from: CammNut on December 15, 2021, 02:59:14 PM
Custard's Last Stand
Someone made the same comment on the fb thread.  ;D ;D
