avatar_philp
Whiffs found on Facebook
Started by philp, June 08, 2013, 10:40:54 AM
killnoizer
Quote from: zenrat on April 10, 2024, 04:41:02 AMThey could have made the effort to add passenger windows.
Maybe there are GREAT Panorama windows under the bay doors ... open just in orbit  :thumbsup:
                     ~ π ~
VDPM Hannover / Germany
2996 Victor
#3421
Quote from: The Rat on April 10, 2024, 07:36:56 AM
Quote from: 2996 Victor on April 10, 2024, 06:20:55 AM
Quote from: The Rat on March 10, 2024, 12:42:22 PMNeat idea, a Wildcat modified as a dive-bomber, by Jose Andres Romero. Still in progress:
I'd be interested to see this - have you got a link?
Forgot to include the link, now I can't remember where it was.  :banghead:  :banghead:  :banghead:
Quote from: perttime on April 10, 2024, 09:36:03 AMIt must be this: https://www.facebook.com/groups/388572005891340/permalink/1134915341256999/
Thanks guys and perttime for the link.
I like it - it's a great premise, although I think I'd have slung a single bomb under the centre line on a crutch like the Vought Vindicator. In fact, I might have to give it a go! The metallic finish is pretty spectacular, too.
Thanks again,
Mark
Mark's workbench:
Spitfire Mk.I Vichy North Africa - Eduard 1/48
Spitfire PR.XIX Rearward-cockpit - Airfix 1/48
Boulton Paul Valiant Mk.I PR - Airfix 1/48
By Jove, I think that's the one! Thanks!  :thumbsup:
That Wildcat looks awesome!
Did Wildcats ever carry bombs or tanks under the belly? I don't recall seeing any. There may not be enough ground clearance. The wing points look good to me and the flaps/ airbrakes look great!
AFAIK the F4F only had underwing hardpoints. However, the SBC, with a similar landing gear, had a fuselage hardpoint, but I have only ever seen an auxiliary fuel tank in that position. IIRC the aircraft had a forked arm to swing the bomb (maybe 500 lb at best?) outside of the propeller disc, though.
2996 Victor
Quote from: kerick on April 10, 2024, 04:11:53 PMThat Wildcat looks awesome!
I've only ever seen drop tanks under the wings
Quote from: Dizzyfugu on April 11, 2024, 01:34:22 AMAFAIK the F4F only had underwing hardpoints. However, the SBC, with a similar landing gear, had a fuselage hardpoint, but I have only ever seen an auxiliary fuel tank in that position. IIRC the aircraft had a forked arm to swing the bomb (maybe 500 lb at best?) outside of the propeller disc, though.
Great drawings on the SBC. I was wondering if a bomb could have been semi-recessed into the lower fuselage and swung out on a crutch like that.
Mark
Mark's workbench:
Quote from: 2996 Victor on April 11, 2024, 03:01:51 AM
Mark
The landing gear placement and geometry makes that unlikely. The recess would have to be farther aft and the crutch longer.
The F4F is cool, but I wouldn't want to do it with one of the folding wing versions. The earlier solid wing would probably be safer.
2996 Victor
Quote from: jcf on April 11, 2024, 12:09:12 PMThe landing gear placement and geometry makes that unlikely. The recess would have to be farther aft and the crutch longer.
Agreed. The F4F has a girder-like structure between the wheel wells - I wonder if that could be beefed up as the pivot point for the crutch. The bomb would then be located farther aft.
Quote from: jcf on April 11, 2024, 12:16:52 PMThe F4F is cool, but I wouldn't want to do it with one of the folding wing versions. The earlier solid wing would probably be safer.
Definitely! The F4F-3 would be the better basis. The SBD had non-folding wings for that reason.
Mark
Mark's workbench:
I wasn't aware that the wing folding was only introduced with the F4F-4, but an earlier fixed wing would certainly be the best basis.
Makes me seriosuly wonder about an extended cockpit with a 2nd crewman in tandem, and maybe a rear-facing machine gun (for an SB2F, an SBF actually existed, a biplane with retractable landing gear).
2996 Victor
So, like a dog with a bone, the whole Wildcat dive-bomber idea is spiralling madly out of control.
This afternoon I've had a little play around with an Eduard F4F-3 fuselage and the bomb arrangement from an Academy (ex-Accurate Miniatures) SBD-1. Suffice to say I think its a go-er, although the Wildcat fuselage would need to be recessed slightly for the bomb itself. Anyway, here are a few pics of the silliness.
Mark's workbench:
perttime
Is it possible to get a recessed bomb loaded on a Wildcat? Without resorting to any awkward structures or procedures, that is.
2996 Victor
Quote from: perttime on April 12, 2024, 11:20:53 AMIs it possible to get a recessed bomb loaded on a Wildcat? Without resorting to any awkward structures or procedures, that is.
Probably not :lol: I reckon several of the fuselage frames would need modifying!
Mark's workbench:
You'll need an extended tailwheel strut.  ;)
2996 Victor
Quote from: jcf on April 12, 2024, 12:41:10 PMYou'll need an extended tailwheel strut.  ;)
Excellent point  <_<
Mark's workbench:
