Steel Penguins braying
Started by Steel Penguin, June 22, 2013, 01:55:36 PM
Steel Penguin
if you read my comments on the new in the stash thread for the weekend just gone.. ( i wait a moment to type more wile you go, and come back  :unsure:  )
I gotted a 1:350 Tamiya King George 5th battleship, cheap !  :thumbsup: , so in the interest of seeing the super detailing stuff, i had a look at the Hannats page   :o  i could spend more that i spent on the kit just replacing the gun barrel's...   maybe ill leave that super detailing thing alone again
Quote from: Steel Penguin on March 31, 2022, 11:52:45 AM
Sounds sensible  ;)
Steel Penguin
part of its my inherant wargamerness,  1 super uber detailed kit, or 3 wargames kits hmmm, which will get me more bang, for my points, on the table ??? ;D  and possibly the later are faster to assemble and paint.  :banghead:
Steel Penguin
broke out ( literaly) the 2nd hand Chally to remove the bits i want to repair / replace on the 2 ive built.  still got to replace the grab handle on the back of the turret "coffin" bin on the second, i think ill have to bend some dental wire for that.  but all the smoke grenade launchers are back on, and the gun crutch part has been replaced.
cleaned up a dozen more 28mm empress 80s brits, after doing 2 multi part ones, i called it a day and got them all superglued onto the 2p peices i use for bases.
nothing finished but the 40 minutes spent doing it is the longest time ive sepent at the desk for an age  :thumbsup:
so happy.
Steel Penguin
second grab handle is superglued as are the supports, im now waiting for the glue to finish setting, before getting out some paint,  ill wait a good wile on this as i dont want to trash any brush`s, knowing how well superglue sets to bristle.  :-\
Steel Penguin
the desert chally if back up to spec  :thumbsup:  grab handle and grenade launcers repainted, one evrythings dried, itll go back in the display cabanet...
normaly im not certain id count it.  but
1 model
Steel Penguin
and the Euro green challys done  both back in the display cabanet.
2 models
Steel Penguin
 ;D  phenomenal compared to last year to tell the truth
Quote from: Steel Penguin on April 19, 2022, 09:45:23 AM
That's what I thought  ;D
Steel Penguin
and as today is world penguin day
WARK!!
Steel Penguin
been superglueing some senery
the small plastic tubes in the center of a roll of plastic bags,  1cm dia, and 6cm ( ish) length, stack them 3 on the bopttom 2 on top and they make great pipe stacks, got 2 already done and a 3rd seting, easy to paint as well, spray grey, and chuck some ink at them then a quick dry brush   :thumbsup:
also found the engines for the 1:48 lear that i had in store ( the model got a pair of 1:48 engines from an A10, they are pretty much the same diameter as the fusalage)  these have gone into the 1:48 Falcon 10 box so i can give that one a set of 4 on the rear kind of like a shrunk in the wash VC10  :thumbsup:
and when i get round to doing the engine less A10 ive got a couple of props from  a busted AC130 to put on.
Steel Penguin
done some more painting on the tau tanks, ( urgh) glued some more of a ganger figure together from Mrs SP,  and scraped the flash and gate lumps off of the 2nd hand space marines i got recently
progression
