Steel Penguins braying
Started by Steel Penguin, June 22, 2013, 01:55:36 PM
Congrats on the anniversary.  Same no. years as mine
Getting there, and well done.  :thumbsup:
The late Mrs_PR19 and I managed 34, but we're very ancient.............
Steel Penguin
thank for Fred and Kit,  seems Mrs SP and i have a way to go, and things to look forward to together  :thumbsup:
Congratulations to you and your better half on your anniversary  :cheers:  Did you remember or were you reminded ?
Steel Penguin
a bit of both  :unsure:   we generaly dont do a lot on the day, and with ot being non weekedn it was just a take out meal in the evening.
did the Penkridge show this morning   shold more stuff that i bought, so good news on that, and Mrs SP did ok at her end of the table as well,  just have to put everytning back in the loft, and wait for the feet to stop hurting. :o
More congrats on the anniversary.  :thumbsup:
Steel Penguin
Steel Penguin
pipe stack is done  :thumbsup:
in among a scrabble through my " unfinised" draw i found the fuel dump from when i recived the resin  trench set mumbble years ago, thats finished and waiting for varnish as well, i will add things to the done count when they are varnished,  im a little further on the industial tank peice, and am still having fun.  YAY  :thumbsup:
Steel Penguin
once more i can be held up as example, so that others can learn from my mistakes  :banghead:   :unsure:
wile superglueing the tanks onto the tank support walls, i may have applied rather more than needed...  this lead to it dripping onto my hand and then running round my fingers just above the knuckle web, seeing that this was going to end poorly, i did the second thing that sprung to mind ( after swearing)  i applied kicker...  and promptly swore again,  that reaction gets HOT,  so i ended up with hand under the running cold tap,   pain alleviated, problem mainly solved, then peeling off the now set superglue..    I am even more grateful that i wear my wedding ring on a necklace, and not on my hand, as the main run would have been over / under / round it...
urgh
stay safe folks!!
Quote from: Steel Penguin on September 16, 2022, 12:42:36 PMits my 22nd wedding aniversary
another case of where did the time go   :unsure:
Late to the show as usual, but congratulations from Madame Rheged and I..............................35.6 years, and just about getting the hang of it.
Steel Penguin
Thank you Rheged, and too madame Rheged  ;D    and congratulations to both of you as well.
Nick
Quote from: Steel Penguin on September 24, 2022, 10:26:24 AMonce more i can be held up as example, so that others can learn from my mistakes  :banghead:  :unsure:
while superglueing....
;D  ;D  :rolleyes:  :wacko:
At least you didn't end up with your hand stuck to any furniture or the kit!
Steel Penguin
nick,  only because i looked down when it felt like something wet was on my hand,   :banghead:   i have ignored things like that in the past, if i was half way through something else.
Get yourself some superglue debonder.
