avatar_lenny100
project "white bird" for operation grapple 1957
Started by lenny100, July 05, 2013, 09:11:59 AM
lenny100
The need for very high altitude sampling during operation "Grapple" in 1957 proved to be a problem.
The aircraft already slated for sampling and weather data were unable to fly at 70,000 feet plus needed and the only way forward looked like weather balloons if the wind were right, not exactly reliable!
Gloster aircraft then came forward with a solution. using the prone pilot meteor f4 prototype they had built but never flown because of wing fatigue problems , with shielding built into the forward pilot compartment and the second cockpit area removed to house sampling equipment, a new sail wing and a specail development of the Derwent 8 engine.
Nick
Looks like a Swan in that white camouflage and the long neck. Maybe Gloster Goose would be better?
deathjester
Oh no  :o  You've talked to Kit again, and NOW look what's happened!!! :rolleyes: :lol: :rolleyes:
Seriously though, that is beautiful - well done!!  :thumbsup:
crudebuteffective
Oh, wow - spectacular!
My only comment would be that perhaps bigger tail surfaces would be necessary?
Oh that is a real thing of beauty...Nice going Lenny
This raises a question, I think.  How long can the wings on a Meteor be?
She is a thing of beauty.  Lovely in that white scheme.    I think "Goose" would be the perfect name for it.
darthspud
Quote from: rickshaw on July 05, 2013, 09:21:42 PM
How long is a piece of string?
Magnificent thinking and modelling there!  :thumbsup: :bow:
Did you use the ENTIRE U-2 wings for the sections outboard of the engines and then trim the chord to suit the Derwent's nacelles?
lenny100
#11
Quote from: PR19_Kit on July 06, 2013, 10:07:13 AM
They are a pair of full airfix u2 wings with only a small cut back on the rear to blend the rear into the nacelles . I stuck them directly on the wing stubs when i cut off the outer wings at the first panel line out from the engines
Gotcha. Way to go for maximum span.  ;D :thumbsup:
When I did the PR19 I trimmed the inboard end of the U2 wings until the chord matched that of the engine nacelles
crudebuteffective
#14
calm down
I call for wing increase length limitation talks (W.I.L.L.T) otherwise this arms or wings race will get out of hand ;) ;D lol
