avatar_Weaver
Micro-Mir
Started by Weaver, October 15, 2013, 12:31:29 PM
Steel Penguin
i would say it was stared by altering the power to / from / through the props. sort of like skid steer on a tracked vehicle. :unsure:
Makes sense.
More sense than the design, but there you go...  ;D
And a turning circle of about the entire width of the Med!  :o
Definitely needs a rudder, in the water or in the air. Maybe both.
Quote from: kerick on February 06, 2025, 07:22:38 AMThere was an interesting Bellanca version of the same idea with what appeared to be the front fuselage of a B-17. Now that would be a kitbash!
Only if you use a B-17 eggplane.You cannot view this attachment.
Water rudders.  One on each float.  Simples.
They'd have to be deep, it might well be clearing the water in ground effect.
frank2056
Quote from: jcf on February 06, 2025, 10:47:44 PM
Wow, you're right. It looks like a Meng B-17 egg plane could be modified with only modest effort:
From this post by Els on ARC
That multi-panel cockpit glazing looks more like a B-36 than anything, not that I'm suggesting hacking a B-36 kit around!
Quote from: frank2056 on February 07, 2025, 09:11:13 AM
I have one of those lying around. Well, most of it.
frank2056
The cockpit section is removable, so even less hacking. The multi panel glazing can be hand-waved away.
Quote from: Mossie on February 07, 2025, 07:53:03 AMThey'd have to be deep, it might well be clearing the water in ground effect.
My thoughts as well Mossie.
So...Mikro-Mir is apparently planning on releasing a Myasischchev M-50 Bounder kit, at least based on this artwork and the artist's notes stating a new collaboration with them
>>LINK!<< for when the token expires.
That'll take a LOT of plastic to mould.  :o
Is it 1/72 or 1/144?
Quote from: PR19_Kit on March 29, 2025, 08:46:17 AMThat'll take a LOT of plastic to mould.  :o
I'd say 144 like the rest of their Myasischchev bombers, but I didn't see anything on the Mirco-mir site.
