avatar_Chris Payne
BAC Eagle - Fighter Version
Started by Chris Payne, October 26, 2013, 03:07:30 PM
Quote from: Dizzyfugu on October 29, 2013, 09:27:53 AM
So much aircraft for so little ordnance...  ;)
I've often had the same thought about British aircraft projects of the period myself. Nice build  :thumbsup:
Geoff
Chris Payne
Chris.
2014 EKFP Total = 8
2015 EKFP Total = 6
2016 EKFP Total = 2
2017 EKFP Total = 7
2018 EKFP Total = 3
Very nice,   :thumbsup:
I've got a load of Red Deans from Colin a while ago, the project I had them planned for didn't pan out the way I thought it would so the missiles will have to go somewhere else, like something along these lines ---
darthspud
Why not  go exotic?
I'm using the various Hasegawa sets of US / NATO ordnance, some Russian ordnance sets and JASDF/Israeli ones too. Just whiffing the markings to suit.
albeback
My thoughts exactly. I know the prototypes were configured for a max load of 10,000lbs but, even that seems not much for such a big, powerful aeroplane. However, (and I hope somebody can confirm/correct me here) I'm sure I read somewhere that the operational TSR 2 would have been cleared for a load of 25 - 30,000lbs?
Allan
ps - nice job though.
darthspud
GOR 339
States
Operational Equipment
17. The aircraft is to be capable of carrying the bomb specified in 0R.1127.
As an alternative secondary role,it is desirable that the aircraft  carry l load of 4x1000lb bombs and a minimum 6x1000lb in an overload case.
So at a rough guess that'd be in the region of 10,000lb including primary strike weapon.
25-30klbs seems rather a lot on such a small wing. I don't think it'd have enough lift for that.
eatthis
Quote from: Hobbes on November 02, 2013, 05:34:25 AM
it used heavy surface blowing like the bucaneer and starfighter but more.
i think it was supposed to be able to take off at around 100k lb in 1000 feet!! (my memory is crap though so im not 100%)
http://tinypic.com/m/hx3lmq/3
darthspud
A lot for the wings, but you could get extra carriage using under fuselage pylons or maybe pylons mounted near the intakes?
Darthspud, it's not about the wing being strong enough, but about the aircraft not having enough aerodynamic lift to get airborne with that load.
darthspud
6,000lbs under wing should give a reasonable secondary load, and keep aerodynamic efficiency to an acceptable level.
alternatively,
why not semi-recess them in a slightly modified pannier under the fuselage, a bit like the F-14 had with those AIM54's or the Eurofighter can do with several weapon types?
