Single Seat Lockheed P-24
Started by KJ_Lesnick, December 23, 2013, 04:02:05 PM
KJ_Lesnick
http://en.wikipedia.org/wiki/Lockheed_YP-24
The design despite being very large and having a rear-gunner was actually quite impressive in terms of speed for its day: I'm wondering how good a performer this design could have been if was built with the same engine, but with only a single crew and scaled down accordingly.  I have a feeling it could've had some seriously amazing performance if it retained good streamlining but weighed similar to the Curtiss P-6E or Boeing XP-9 (both had the same OEW: 2,669 lbs; the P-6E was 3,436 lbs loaded and the XP-9 was 3,639) rather than it's actual size.
What do you all think?
I think that your habit of deleting and then reposting a topic when you don't get a response and/or the response you want is very irritating.
:banghead:
Quote from: joncarrfarrelly on December 23, 2013, 05:48:20 PM
:banghead:
And reposting the same question(s) slightly modified is another bad habit.  Witness the "big and small diver bomber" thread.  We've been over dive bombing several times Kendra/Robyn.  The answers will not change.   Stop trying to compare apples and oranges all the time.
A Canberra pilots description of a 20 degree dive to fire RPs "pretty alarming, you were hanging off your straps."   I doubt very many large aircraft carried out 40 degree dives.
KJ_Lesnick
joncarrfarrelly
QuoteI think that your habit of deleting and then reposting a topic when you don't get a response and/or the response you want is very irritating
I apologize for being irritating, but from my perspective it's very irritating when I ask a question and nobody answers ;)
Rickshaw
QuoteWe've been over dive bombing several times Kendra/Robyn.
I was doing some research on the XA-23 Baltimore and they said it could dive up to 0.74 Mach which is higher than some fighters at the time were good for (the P-38 for one) and they were able to do a steep-dive up to at least 450 followed by a successful release and pull-out far as I know.
QuoteStop trying to compare apples and oranges all the time.
As for comparing apples and oranges, I think the A-20, B-25, and B-26 shouldn't even be considered in the same class the A-17, SBD, SB2C, and A-1 are in.  However the A-20, A-24 (SBD), A-25 (SB2C) A-26 are actually technically in the same class silly as it is.
