avatar_TallEng
Spitfire with 2 Griffons (push/pull) finally finished
Started by TallEng, January 20, 2014, 01:39:50 PM
Father Ennis
I agree with zenrat ,if it looks right it is right.   So just follow your Muse !!!
TallEng
Thanks for the positive comments gents :thumbsup:
Smallish update:
You might be able to see the enlarged radiators, and you can definitely see the cardboard mock up of the fins,
Does the bottom fin make it look to big/heavy at the back? Aka (does my bum look too big in this?)  ;D
Keith
dumaniac
eeeee gads - shades of 335
looking good - the paint work will pretty it up
Hopefully she can stil fly once all that power rips the wings off !
eatthis
great job fairing the rear engine in  :thumbsup:
i wish youd moved the wings aft though its gonna be a real tail heavy bugger as it is
http://tinypic.com/m/hx3lmq/3
2 Griffons increased the speed so much... the Air Command asked Supermarine: what-if you install FOUR Griffons?
Thanks! :cheers:
Quote from: eatthis on February 03, 2014, 08:38:31 AM
Just make the horizontal tail surfaces bigger and say the added lift corrects it.
The boys at the engine plant will have to work even more overtime!
eatthis
Quote from: kerick on February 03, 2014, 09:57:36 AM
lol i didnt realise the tail gave much lift i always thought the tails were fairly nuetral
nighthunter
I'd make the top fin a bit larger, and reduce the tail a tad, not too much though, Looks great and a great place to stick the tail wheel...
Quote from: eatthis on February 03, 2014, 10:05:17 AM
Actually tailplanes usually give negative lift to aid the stability of the whole aircraft.
Good work so far.
I'd lose most of the bottom fin, leaving just a small triangle, make the horizontal tail surfaces wider and add fins at the ends.
But that's going away from the Spitfire look a bit more.
FAR148
eatthis
are you doing it wheels up or are you gonna wonder how the hell to give enough ground clearence like i did lol
TallEng
Quote from: eatthis on February 07, 2014, 09:36:14 AM
I might have a cunning plan for the wheels.....
of course if it doesn't work, wheels up is always an option :lol:
Keith
