avatar_The Chaos
BV 155 and JU188E Mistel Gespan. 1/72 Finisched
Started by The Chaos, August 28, 2014, 05:39:29 AM
The Chaos
Hi guys , I try sometimes hereby WIF Airplane modelling.
it should be a mistletoe bailiff. from the rabbit JU188 and the Airfix BF109. at the JU I have the hull built together and share built the bomb head and worked with Aves with diverseness other. as flyers are not so often build of me , I 'm curious about your opinions times.
That warhead looks funky! Could also take a canopy, for a fast reconnaissance version...?
The Chaos
update :
the top of the bomb I have again revised and added to a propellant plant on the roof.
This should improve the transfer ignited during the release of the bomb as a higher speed to give, the defensive fire a bad chance.
As a carrier aircraft. I now if I should take the Focke Wuld A- 8 or from this 3 kits myself what build or still better a arrow
The 190as it used the same grade of fuel - meaning it could fly on fuel from the bomb until release, meaning greater range.
"Visit Scarfolk today!"
dumaniac
love how you have covered over the Ju188 cockpit
great start to an interesting mistal
Bernie
albeback
Very interesting concept I like this. One question though, are you planning a single vertical tail fin or, V-Tail/tail fins mounted on the ends of the tail planes? I cannot help but wonder what the effect of the jet exhaust would be on a single vertical fin and rudder?
Allan
Looks wild ! Love the shape of the new nose area.
The Chaos
update : Hi guys , here the JU with Bostern at the wing tips. ( In some prototypes , there was the well )
The Chaos
update : I remove the small wing tip and mounting the main engine. ( here I had a lot of filling )
The Chaos
Update: the mistletoe is now assembled Finish. now follows the carrier aircraft.
The Chaos
Update:
The BV 155 started to fit , there is not really filling and I 'm going to have with Aves.
The Chaos
