avatar_Dizzyfugu
DONE: SAAB OAS 41, Swedish Air Force; F 7 at Satenäs AB, 2014; beauty pix @p. 3
Started by Dizzyfugu, September 30, 2014, 02:11:52 AM
What Dizzy means by a 'busy weekend' is that he has 4 other models to build before Monday.  ;D :lol:
No, that's a normal weekend.  A busy weekend is 6 built plus 2 shows at different ends of the country while moving house.
nighthunter
Finally...  ;D
1:72 SAAB OAS 41 'Víðarr'; aircraft "23 Grey" of Skaraborgs Flygflottilj F 7, Swedish Air Force; Satenäs AB, 2014 (Whif/kit conversion) by dizzyfugu, on Flickr
Some background:
The Víðarr (or Vidar, "Wide ruler", a Nordic god among the Æsir associated with vengeance) or officially SAAB OAS 41 is Sweden's first manned aircraft with stealth technology, and the first aircraft of its kind in Europe in operational service.
"OAS" is an abbreviation of the aircraft's primary tactical roles: "Osynlig Attack Spaning", "Unseen attack and reconnaissance missions". Much of the OAS 41's technology and elements were developed and tested on unmanned vehicles, namely SAAB's SHARC and FILUR demonstrators.
SHARC (Swedish Highly Advanced Research Configuration) was an experimental unmanned aerial vehicle (UAV) built by Saab AB. Since the late 90-ies SAAB had been carrying out preliminary studies about several Unmanned Aerial Vehicles (UAV) concepts but not taking them into flying demonstrators.
In 2001 it was decided to start the SHARC Technology Demonstrator (SHARC TD) project.
Because of a limited budget and good in-house experiences from flight tests of instrumented sub-scale aircraft, it was decided that the SHARC TD should be in 1:4 scale of the original SHARC design. One of the major goals of the project was to test the airworthiness process for a military UAV or aircraft of similar layout, and this could well be achieved even with sub scaled aircraft. Even the goal of testing a lean development process for demonstrators could be achieved in that way.
The SHARC TD project was initiated in 2001 with first flight less than one year later, on February 11th 2002, with the basic version. The more advanced version made its maiden flight on April 9th 2003, less than two years after project start.
In September 2003 the SHARC flew a number of missions out of visual range, ranging around 20 km from the control station location. In January 2004 the effort towards the development of the ATOL functionalities was initiated, and led to a successful flight test campaign in August 2004, during which fully autonomous mission were demonstrated, from standstill to standstill.
The SHARC system was composed by two flying demonstrators (BS-001 and -002), a GCS and some GSE for engine start and cooling air supply on ground. The SHARC TD is a 60 kg jet-engine driven aircraft. The airframe was manufactured in light-weight composite materials; the airframe weighed only 8 kg (without landing gear).
The payload consisted of a forward looking colour video camera. The avionic system (hardware and software) was designed and manufactured by SAAB and is based on Flight Test Instrumentation system COMET 15 used in the Gripen and Viggen fighter a/c.
Before the decision to develop an in house avionic system, a market survey was conduced, but no existing system had been fulfilling specifications. Electro-optic fibres, or "fly-by-light", were used to the actuators in order to minimize the risk for Electro Magnetic Interference.
Saab and FMV's technology demonstrator program FILUR made its first flight in 2006. FILUR's main objective was to show the tactical importance of stealth technology applied on aerial vehicles, to gain experience and to set a foundation for stealth requirements for future aerial systems and air-surveillance systems.
The focus with the FILUR program was on low signature, for both radar and IR-signature. "Static measurements of radar cross section (RCS) made late 2004 showed really good performance and corresponded with calculated data. In flight measurements of stealth performance will be done as a next step", said Jan Boström FILUR Project Manager, Saab Aerosystems.
The technology developed in FILUR would be used for future Saab systems, being UAVs or manned aircraft, which became the OAS 41 which had been under development since 2004.
The SAAB OAS 41 made its maiden flight in 2012, and in early 2014 a pre-production batch of five aircraft has been assigned to Skaraborgs Flygflottilj ("Skaraborg Air Force Wing") F 7  in Satenäs, where the aircraft are operated alongside JAS 39 Gripen multi-purpose fighters for evaluation and integration.
Conceptually the OAS 41 is very similar to the much earlier US-American F-117, dedicated to ground attacks with precision weapons, attacks against coastal/sea targets and reconnaissance missions.
All ordnance or equipment is carried internally in a large bay which is covered by sliding doors. Typical weapons include up to three Rb 75 (AGM-65 Maverick) missiles, two GBU-12 laser-guided smart bombs or two AGM 119 "Penguin" anti-ship missiles. Iron or cluster bombs as well as pods with unguided missiles are also an option.
Beyond that, the aircraft can also carry air-to-air missiles like the actice radar RB 99 (AIM-129 AMRAAM) or the IR-guided Rb 74 (AIM-9L Sidewinder), up to four of each.
The OAS 41 does not feature an internal gun, even though up to two podded Mauser BK 27 cannons can be carried internally. Overall, its range of weapons is highly identical to what the JAS 39 Gripen can deploy.
Alternatively to offensive loads, the OAS 41 can carry camera of sensor pallets in its belly, making it highly adaptable.
It is uncertain how many aircraft wil actually be built, since the Swedish Air Force officially announced that the OAS 41 is not to replace its JAS 39 fleet, rather complement it or take over exclusive missions due to its stealth features. The type's limited performance will probably confine to a limited scope of missions, and with the running cost reductions it is not expected that more than 30 OAS 41's will ever leave the production line for the Swedish Air Force, unless it would be exported and follow in the Gripen's footsteps, but this remains doubtful.
General characteristics:
Crew: 1
Length: 6.70 m (21 ft 11 in)
Wingspan: 18,29 m (59 ft 11 in)
Height: 3,96 m (13 ft)
Wing area: ~68 m² (729 ft²)
Empty weight: 6.739 kg (14.844 lb)
Internal fuel: 2.500 l
Max. takeoff weight: 13.600 kg (29,760 lb)
Powerplant:
2× Svenska Flygmotor RM13S turbofans (General Electric CF34-3S), with 4.150 each
Performance:
Maximum speed: 692 mph (1.115 km/h) at height
Cruise speed: Mach 0.7
Landing speed: 210 km/h
Range: 4.828 km (3.000 mi) with internal fuel
Service ceiling: 13.381 m (43.830 ft)
Rate of climb: 60 m/s (11.811 ft/min)
Armament:
Up to 3.000 kg of ordnance, all carried in a ventral bomb bay, including air-to-ground and air-to-air missile, smart and iron bombs, gun and rocket pods, ECM equipment and pallets with cameras and sensors for reconnaissance missions.
The kit and its assembly:
This stealth aircraft is basically a scale-o-rama project: it is a Dragon B-2 bomber in 1:200 scale turned into a 1:72 scale aircraft.
What sounds easy is more complex than it appears: you need a cockpit with a proper canopy, the landing gear has to be adjusted and there are many small details that need attention.
For the cockpit installation I decided to implant a complete X-32 section from a Revell kit, it replaces the complete B-2 spine. It appears a bit bulgy, but upon close inspection of the potential internal layout I found that you can either have a flush canopy OR a bomb bay. Since I wanted to keep the latter (and enlarged it), the cockpit went a bit higher.
1:72 SAAB OAS 41 'Víðarr'; aircraft "23 Grey" of Skaraborgs Flygflottilj F 7, Swedish Air Force; Satenäs AB, 2014 (Whif/kit conversion) - WiP by dizzyfugu, on Flickr
As a result, the original X-32 canopy looked much to bulbous, it was way too high. Searching through the spares pile I eventually turned up an old F-18B canopy, which, reversed and cut into shape, could be transplanted onto the X-32's cockpit frame, even tough some sculpting at the rear was necessary. Since the F-18 canopy had some glue stains I had to sand and polish it, and as a final coat I decided to apply some light brown translucent paint. Fit is not 100%, though, but it looks good now.
The high cockpit necessitated some visual counter-balance at the rear. Originally I had hoped to keep the OAS 41 fin-free, but I eventually dug out a pair of F-117 fins that were cut down in length and glued to the airframe, slightly canted outwards.
The landing gear is all new. The massive front strut comes from a F-117, the wheel from the X-32. The front well was enlarged, as good as possible, but it is still too short... don't lokk there closely. ;)
The main landing gear struts were taken from the X-32, while the wheels come from the F-117. The wells were lengthened at the rear, so that the longer legs find enough space.
The B-2's original bomb bay was cut out and replaced by a completely scratched interior that allows the carriage of a pair of laser-guided bombs, which come from the scrap box.
The exhaust slits were modified, too. They were made wider, and inside a kind of ramps were added - the original 1:200 B-2 has nothing inside. For the same reason I also added light blocks, pieces of dark grey foamed plastic, inside of the air intakes and the exhausts.
Finally, at the aircraft's front, some pitots were added, but that's all since the overall hull was to remain clean.
Painting and markings:
I originally had the plan to make this a Japanese aircraft, but then I decided to make it a (kind of) tribute to the innovative Swedish aircraft industry - the SAAB OAS was born, and it was to carry an appropriate, if not odd, paint scheme.
Even though "Fields & Meadows", made popular by the Saab 37 Viggen, was an option, I did not want to copy that style. But an angular scheme appeared logical as to confuse the aircraft contours. The splinter paint scheme I eventually settled upon was vaguely inspired by Norwegian "Skjold" class coastal patrol ships, which have stealthy hulls and carry a three-colored spinter scheme in grey, sand and dark brown. Odd for a ship, one might say, but in front of the typical Norwegian rocky coastline, it is highly effective, and even on the open sea, viewed from above, it is not a bad scheme at all.
The pattern was vaguely lent from the Skjold boats, and I used different tones which would IMHO be more versatile: a reddish brown (WWII French Earth Brown), Field Grey and Olive Drab, in  a wraparound scheme.
Together with the edgy shape of the aircraft this turned out to be pretty effective - a bit of a surprise!
The rest was rather straightforward: white for the air intakes and the landing gear, the cockpit and the bomb bay were painted in Neutral Grey.
The pair of internal GBU-12s was painted in light grey, a typical tone for such weapons in Swedish use witn the JAS 39 Gripen.
The kit received a light black ink washing and some panel painting with lighter shades of the basic tone, just to amphasize contours and simulate some structure and acccess panels esp. in the engine area.
After decal application (puzzled together, among others, from an Italeri JAS 39 Gripen) the kit was sealed with Revell's matt acrylic varnish.
In the end, a rather simple whif - I am not a friend of stealth aircraft, since they are IMHO boring. The splinter scheme changes this a bit, and the high cockpit does not look that bad at all, even though the original X-32 canopy looked REALLY weird.
That is a very interesting little bird ! Nice work. Love the camo. I do agree, the usual suspects are so boring. Be a lot easier to hide on the ground this way too !
Impressive and inspiring.  I too am not a friend of the stealth plane but you have shown that they can be made interesting with a bit of thought.
flappydaffy
 :bow: :bow: :bow: :bow: :blink: :blink: :blink: :blink: must be stealth, i didn't see that one coming but it's awesome !!!!!
Somehow i missed this one... :o Beautiful! That just blew my socks off! :thumbsup:
