avatar_zenrat
Zenrat's Flying Circus
Melbourne was experimenting with pedestrian crossing repeater lights set into the kerb at crossings.  The idea being that those looking down at their phones would see them.
Not sure how the trial went.
During the comedy festival one year there were people engaged to shout "phone down, eyes up" at those in danger at crossings.
Over the last couple of weeks I have succeeded in getting paint and transfers on the tank and side panels of the Hasegawa Kawasaki KH500 without crazing.  I achieved this using purely Tamiya paints.  I was going to make the final white colour coat Fine Surface Primer with clear on top but then while checking my paint shelves I discovered I had a couple of still sealed rattle cans of Tamiya Pearl White so I used one of them.  It looks good and should look even better once cleared with Tamiya Clear.
Over the weekend I masked (have I mentioned my dislike of masking?) and sprayed some panels on the second of the '60 Chevy Utes.
And also over the weekend I began PSR on the Monogram '39 Chevy Coupe i'm fitting with a Galaxie Models Chevy six.
Felt like rigging a biplane and building a civil aircraft so I pulled something out of the stash i've had in there a while.
It's the Tasman Models DH Dragon Rapide.
DH Dragon Rapide 02 by Fred Maillardet, on Flickr
Fuselage halves are curved (I won't say warped as they are both curved the same amount).  I've glued the nose together and will work my way to the back when i've got the interior sorted.
Great box art.
DH Dragon Rapide 01 by Fred Maillardet, on Flickr
Interior floor is not only warped but appears short shot at one end (or it's just been moulded asymmetrically).  It's basically a flat piece so i'll scratch up a replacement.
DH Dragon Rapide 03 by Fred Maillardet, on Flickr
It'll be in the livery of one of the small airlines that proliferated in the PDRV pre war.
I also tidied my bench and installed a new A2 cutting mat.  Don't worry, it won't stay this tidy for long.
Bench 02-01-2021 by Fred Maillardet, on Flickr
I got that same Tasman Upgrade kit ages ago, mainly because an RAF Dominie was the first aircraft I ever flew in, and I fancied making a model of it.
Naturally I've never built that model............yet.  :banghead:
But I'll go and check it now to see if it's warped as well. Thanks for the memory jerker Fred.  :thumbsup:
I always find with nice new clean things like that cutting mat that I'm concerned about messing it up until the first "splodge" (a technical term) of paint falls on it and then I can't give a monkey's  :rolleyes:
A new mat... noice !
As you correctly say, will not stay that way for long.. if you are doing things correctly that is i.e. actually using it for building things.
I sometimes wonder at photos you see of "work spaces" that are super tidy and super clean.. what do they do, outsource the building ?
Quote from: buzzbomb on January 02, 2021, 02:12:08 PM
My own view is that some people have the "tidiness gene" and others don't. Also it helps to keep your work area tidy if you are one of those who manages to just work on one model at a time. I admire people who can do that and those who can keep a tidy work area, I certainly can't.
I DEFINITELY don't have that gene!  :-\
I've already dripped Tamiya Extra Thin on it and removed some of the print.
The new one has a coarser texture to my previous mats.  I feel it may look shabby quicker.
Quote from: zenrat on January 04, 2021, 02:57:50 AM
You probably feel quite relieved at that  ;)
Nice to see one of the Tasman Rapides getting to a cutting mat to be built... I look forward to actually seeing one completed.  :thumbsup:
I built a couple of their Oxfords back in the day, and while they were a workout, they did go together and looked good in the end (if I say so myself!).
Just take things slowly and think through what you need to do and you'll be ok. (I had issues, but most of them were of my own making)
Their Airtrainer is also a nice little kit.
Quote from: Rick Lowe on January 04, 2021, 01:09:46 PM
I've had this for years.  Thought it was about time I built it.  I need to plan out the order of things to get the interior painted and installed nicely along with the windows.
Oh hell yeah.. civil... airliner... true whif from a universe of your own creation.....   this is going to be awesome! I swear I don't know why more folks don't do projects for stuff that doesn't exist?
You could fit a pair of floats on your model if you have any spare.
Good idea Mac but as the engines are on the lower wings I think the props would be a bit close to there water and susceptible to spray.
Flyer
#3704
Quote from: zenrat on January 06, 2021, 02:53:39 AM
I'm sure I've seen a picture of a Dragon Rapide on float's somewhere...
Engines being directly above the float's should offer a little protection maybe...
Or totally wif it and put the lower wings on top  ;)
Edit: https://www.google.com/search?q=dragon+rapide+on+floats&client=ms-android-optus-au&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiJos27pIfuAhWDguYKHVbZAx4Q_AUoAXoECAUQAQ&biw=320&bih=490&dpr=1.5
