RAF Fighters & Ranges
Started by KJ_Lesnick, January 15, 2015, 12:41:32 PM
wuzak
Morgan and Shacklady have a picture of two Mk IIs with underwing fuel tanks. These look to be similar to a Mk I with an underwing overload tank fitted to one wing. The latter is certainly a fixed tank, not a drop tank. The former looks to be the same.
In any case, they are experiments aimed at extending the range of the Spitfire, not production models.
I've another book on the Spitfire (I'll look for the title later as I'm off to work soon). There's a series of photos of a Spitfire dropping a cylindrical center line drop tank. Going by memory it looked like something that was later fitted to a Spiteful/Seafang
KJ_Lesnick
Quote from: wuzak on June 11, 2015, 04:01:13 AMThe only drop tank options for the Spitfire used in service was the slipper tank.
There were some tank designs to be carried under the wings I've seen -- they were right under the guns
QuoteRear fuselage, not the upper and lower tanks in front of the pilot.
I'm aware of exactly what I'm saying: I know the plane normally had an upper and lower fuselage tank.  However, I do remember a statement that stated an aft tank that had a 33 Imperial Gallon upper and 41 gallon lower tank.  I'm just operating on what I read
QuoteWhere did you check?
Google-searches, and wikipedia
wuzak
Quote from: KJ_Lesnick on June 15, 2015, 11:14:25 AM
Was it a test airframe or a service aircraft?
I believe that the two different rear tank sizes were for the normal fuselage and the cut-down fuselage with bubble canopy.
KJ_Lesnick
#79
Wuzak
QuoteWas it a test airframe or a service aircraft?
Unsure
QuoteI believe that the two different rear tank sizes were for the normal fuselage and the cut-down fuselage with bubble canopy.
Makes sense
KJ_Lesnick
I'm looking at something here and I'm not sure if this is right: http://www.ww2aircraft.net/forum/flight-test-data/ww2-fighter-critical-mach-speed-802.html
According to some things here, supposedly the wing was good to Mach 1.3, but the propeller produced massive turbulence that rendered the tail useless, along with shockwaves on the tail impairing elevator control: Is this correct?  Under this logic, one could just build a jet around a Spitfire wing, put a stabilator in the design, and strengthen the fuselage and you'd have a supersonic design...
wuzak
It was stated that the wing was good structurally for Mach 1.3, not that it was low drag at that speed.
KJ_Lesnick
Wuzak
The question is was it aerodynamically good, and how well would the tail work if you had no propeller?  Would you need an all moving tail?
