avatar_Old Wombat
1/35th FSBR - Fire Support Boat, Riverine
Started by Old Wombat, February 18, 2015, 01:17:58 AM
Thanks, Chris! :thumbsup:
Generally they were no more top-heavy than your average power boat or motor yacht. Their engines were low in the hull, their main weapons systems tended to have most of their weight below deck level, their superstructures were no higher than they had to be & most were wide-beamed boats, like MTB's & PT boats. They, also, tended to be made of aluminium or GRP's (Glass Reinforced Plastics) & carried very little in the way of armour.
The river monitors were usually barge/scow-like hulls &, again, kept the majority of their mass close to the waterline or below it.
Quote from: Old Wombat on July 10, 2015, 07:31:05 AM
Ah, that answers it. It was the weight of the weapons systems in particular that worried me. You live and learn, thank you sir  :thumbsup:
Quote from: Old Wombat on July 09, 2015, 07:48:00 PM
You may now see how little progress has progressed. :blink:
Well, maybe little progress but it's significant progress, GUNS!!  :wacko: :thumbsup:
Not a problem, Chris! :thumbsup:
Thanks, DfZ! Yep, guns is good! ;D
Still slow progress due to p!$$-poor weather, work & family commitments. :-\
Well, I've been doing little bits & pieces ... & I got carried away with the rusting. :blink:
Honestly, I was just enjoying playing with the AK rust paints I bought & was enjoying being impressed with the results even my ham-fisted painting could achieve.
So, although in real life no Royal Australian Marine would dare let their vessel/vehicle get even close to this badly rusted, I'm leaving it as is.
Should be finished, finally, in about a week. Photo's then.
Guy
Cool. It would be nice to know how you did the rust that's somat I really would like to try proper.
Fire Support Boat, Riverine (FSBR) Mk.II
Length: 51 feet 8 inches (15.75m)
Beam: 15 feet 6 inches (4.72m)
Draught: 24 inches (61cm)
Displacement: 20.67 long tons (23.15 short tons / 21t)
Propulsion: 2 x 270/370 hp (201/276 kW) Cummins VT8-370-M turbocharged marine diesel engines,
                      each powering a Caldwell & Lacey TP12M turbine water-jet with a thrust bucket for
                      reverse thrust.
Speed: 22.5 knots (25.25mph / 41.85 km/h)
Complement: 10 - 12
Armament: 2 x 40mm Bofors multi-purpose autocannon in a US M-42 twin-mount turret (248 rnds)
                      1 x 20mm General Dynamics M168 Vulcan rotary cannon (30,000 rnds)
                      2 x .50 cal Browning M2HB machine guns (3600 rnds)
                      Assorted personal small-arms
Armour: Hull – ¼ inch mild steel plus internal reinforcing up to ¾ inch
                Superstructure – 1 inch armour grade aluminium
The Fire Support Boat, Riverine, Mk.II was an Australian-built vessel designed for operations in the rivers & deltas of South East Asia utilising primary & secondary weapons acquired from US forces in Vietnam.
Operated by the Royal Australian Marines of the Joint US-Australian River Patrol (JUSARP) from 1967 until the withdrawal of Australian main force units in 1978, when they were handed over to the Republic of Viet Nam Navy (RVNN).
The FSBR's were generally used with RAM PBR 31 Mk.II's in operations against North Vietnamese / Viet Cong supply bases along the river. However, they often served as flank-guards for main force land operations in the Mekong Delta & River areas, & as fire-support for RAM Special Boat Service infiltration & extraction operations, & US Navy SEAL activities all along the Vietnamese coastal & riverine areas.
Only 6 of these boats were built, including the 2 Mk.I's which were converted to Mk.II standard. As river boats the FSBR's were quite exceptional, with a rapid acceleration & impressive agility for their size. However, they lacked sufficient crew accommodation for extended patrol operations & had generally poor ride qualities in all but the calmest seas. Despite this they were the preferred support boats for special operations teams as they were fast, heavily armed &, with their exhaust gasses exiting via the water-jet units, quiet.
Depicted is FSBR Kilo-Four (a.k.a. "The Real Thing") as she appeared at the height of the 2nd Tết Offensive, in 1975, during short a Rest & Re-armament break. In the cockpit is the Duty NCO, Corporal Lionel "Snowy" Walters.
(Note: These are the last photo's before the cockpit roof was glued in place.)
Lidded, roofed & covered.
(Link to new SmugMug album: https://guyplachy.smugmug.com/RAM-Fire-Support-Boat-Riverine/)
Well, except for a bit of loose gear floating around, that's it!
FINISHED!
:thumbsup: :cheers: :party:
Steel Penguin
That's a TRULY First Class job you've made of that Old Wombat. I'm really, REALLY impressed!  :thumbsup: :bow:
That last batch of pics showing the cockpit with all the stuff you've added is as good as I've ever seen on a model boat of any scale, super stuff.
Yep, that's what i call 1st class work too!!  :bow: All the detail work, those guns... and the Vulcan cannon... Beautiful! :thumbsup:
nighthunter
Thanks guys! :bow:
After a while all you see are the flaws.
It's good to get some outside perspective - especially when it's positive! ;D
A link to the song that inspired the name: https://www.youtube.com/watch?v=HImcaPDmfBY
Worth the wait.  A marvellous piece of building.  Makes me want to dig out a boat kit.
Thank you, gents! ;D
And extra thanks to Kit for the much appreciated Whiffie nomination. :bow:
