avatar_sandiego89
Jump-Jet-Jag
Started by sandiego89, April 03, 2015, 03:14:14 PM
I'm in!  :o
With the realization that the VTOL Mirage IIIV was never going to turn into a practical aircraft, and with too much pride to order the GR1 Harrier, France opted for a STOL Jaguar with a lift jet that would allow STOL operations from short, austere strips....
Jump-Jet-Jag
1/72
The old raspberry ripple T2 is being used for test measurements and dry fitting only.
Various carriers, dreadnoughts and cruisers also for scale.
Looks like a neat idea.
:tornado:
#2
Quote from: Captain Canada on April 03, 2015, 10:03:14 PM
Ha, Captain a bit of fleet crept into the shot.  Here is a family shot of a few of them:
1/700 scale USS Currituck and 1/700 Ashland class LPD.  Both scratch-built with balsa, and updated as part of the US Navy Seaplane Striking Force, with a scratch built P6M Sea Master in the welldeck of the LPD, CONVAIR Sea Darts on the deck of the tender and a scratch Tradewind to keep the task force replenished.  They all need a little loving care, and have lost masts etc from being in the danger zone on the workbench.
The carrier is a scratch stryrene 1/700 Melbourne. Have plans for a Bonaventure WHIF resurrection  ;)
Back to the Jaguar:
Scratched up a Adour. An Adour (without afterburner) is 77 inches long.  Will serve as a lift jet in place of the back seater.  Just enough room to fit inside the Jaguar when mounted at a angle.
I though about going with a RB lift jet, but decided the SEPECAT/SNECMA design team opted for engine commonality with the two main engines.
Non- afterburning Adour from a 1/48 bomb casing and a 1/72 spitfire main wheel.
Test fit of the lift jet in the tub where the rear seat crew member would normally be in a twin stick Jaguar.
dry fit of the forward fuselage halves.
Getting ready for fuselage mating.
Nice project, and ambitious for a 1-week GB. :thumbsup:
The Jag was pretty good at STOL in standard configuration (at least at low weights), but you've got me thinking now: what about something with noriously bad runway performance, like a Thud? You could do this to an F-105F... :wacko: (I've got one, but it's for a different project).
#5
Installed a heat shield/engine bay bulkhead behind the lift engine.
Lift engine in.  You can see how I had to angle it aft to clear the forward landing gear bay.  I could have just made the top and bottom of the lift engine, but I wanted the challenge to see if I could slide it in.
Buttoned up.  Gun pod, one side only, blank on the other side.  Back story was that the gun space was needed to re-route some of the lines- real story is carpet monster got the other blank.  Kit comes with two gun pods, or two blanks.
Test fit of the lift jet door. In the closed position here.  Hawk enthusiasts might notice the shape and bumps.
#6
Installation of thrust deflectors, or as the crews referred to them "boules de sucre" (sugar scoops)
Could be deflected up to 32 degrees to boost STOL performance (in dry thrust)
I initially read the title as Jump Jet Lag so was expecting a Harrier  ;D
Cool project. Had the VTOL craze lasted a bit longer, they'd have come up with this for real.
Nice!  :thumbsup:
Is the wing already glued on? If not, you could have a Crusader-style variable incidence wing which would also help with the take-off performance. I think someone on here did such a Jaguar before, but I don't recall who at the moment.
Thanks for the update on the boats.....wow !
Love the engine config on the Jag. This is going to be awesome !
:cheers: :bow:
Quote from: ChernayaAkula on April 06, 2015, 02:01:23 AM
Nice!  :thumbsup:
Ohh, that would have been a good idea, but too far past it now as she is glued in pace (at least for a one week build).  She does have a blown wing however, with bleed air from the lift jet.
Glenn Gilbertson
KiwiZac
Ooh yes I'm liking this! Great work with the lift jet, and those thrustery bits are beautiful!
Zac in NZ
https://linktr.ee/zacyates
Great progress!
So am I right in thinking that the Italeri Jag has the guns moulded as separate pieces, with alternative blanking plus then? If so, veeeery interesting.... <MODE = MR BURNS>
#14
Quote from: Weaver on April 07, 2015, 06:46:58 AM
Great progress!
Exactly, the kit has a port and starboard gun, or alternatively a port and starboard "blank/no gun" so you choose what you want: guns or no guns (or even one gun, one blank) .  All are crisply molded and go nicely into the rectangular cavities.  This rectangualr cavity is easily seen in the photos below.  The blanks have a very nice curve that matches the complex curves near the rear of the pod.  The guns are also very niceley molded. The kit is very clever, and the gun pods act as reinforcement as they are half on the forward cockpit area, and half on the rear section of the jet.  I believe the kit was designed to have the fuselage break just aft the second seat to maximize commality between single seater and the two seater kit.  All the two seater parts (forward fusealege, second seat, guns, etc) are on a separate sprue.
A very nice kit.
