World War One Whifs
Started by stevehed, April 10, 2015, 12:07:06 PM
Very nice. :thumbsup:
An underslung radiator ala the Bristol F.2B and DH.9A aircraft modified for use in the Middle East and South Asia (Afghanistan, NW Frontier etc.) would also be a possibility.
Is the Ninak carrying a spare wheel?
Full size too, not a space saver.
Quote from: zenrat on May 06, 2024, 05:14:58 AMIs the Ninak carrying a spare wheel?
Yup, they quite often carried them in some of the farther slung reaches of the Empire. Just in case they needed to land for something and damaged a wheel on a rock or similar.
stevehed
#273
While seeking inspiration I discovered that Pfalz had not used the thirteen designation. A little thought came up with a possible candidate. At the beginning of 1918 the Pfalz DXI was tested but failed to obtain a production order. It was later described as a Pfalz DIII fuselage with wings which resembled those of the Fokker DVII. Unlike the Fokker the wings were not cantilever and were wire braced. The Pfalz DXII was ordered into production and was a two bay wire braced machine. The DXIV was a DXII with a 200hp Benz engine which did not enter production while the Pfalz DXV possessed cantilever wings and entered full production in the last weeks of October. It would have replaced the DXII and was to be powered by the much sought after BMW engine. In this time line the war continues into 1919 and the DXII's are being returned to the training units. Still a capable fighter it was felt that some of these machines could be used to bolster the Turko-German units in the Middle East.
These units were already receiving tropicalized examples of the Albatros DVI, Fokker DVII and Fokker CI. While the DVI was a standard wire braced machine, the Fokkers were cantilever and sported very little bracing. It was felt that the twin bay Pfalz DXII might not be the best aircraft to send into the high temperatures of the Middle East where there was already a shortage of trained ground crew such as riggers. The Pfalz DXIII came about as a potential solution to the need to maintain supplies to Germany's allies. Pfalz engineers suggested replacing the lower wing with a cantilever version based on the Fokker DVII. The earlier DXI upper wing had a wider chord and could be used to complement this new wing with added lift.  The twin interplane struts were replaced by wireless V struts in a Warren truss arrangement and extra lift was sought by the addition of a Fokker type axle wing. My degree in aerodynamics was achieved by an afternoon's study at the University of Wikipedia and this design could be described as semi-cantilever. The type flew in November 1918 and was declared fit for operations by January 1919.
Pfalz were fully engaged with production of the DXV so Idflieg needed a company that could convert DXII's to the new DXIII configuration.  Eyes fell on the LMA company that was using Albatros DV airframes to produce DVI aircraft. This involved the construction of new wings which the Pfalz DXIII would also need. Their near neighbours at Avia were refurbishing Argus engines for the German airforce and had capacity to take on more work. Idflieg needed upgrades to the latest specs to many Mercedes engines and Avia had geared up to take on this work. LMA agreed to manufacture the new wings and were allocated new Mercedes engines for the completed DXIII's.
The first batch were sent to Istanbul for assembly and flight testing. It had been expected that the larger capacity radiators fitted as standard to the Pfalz would suffice in the hotter climate but overheating soon became an issue. As a temporary fix two sections of the radiators fitted to the Fokker machines were installed on the sides of the fuselage. This fixed the cooling problem but German designs had not been allowed to incorporate this method since Nov 1916. Damage sustained could drain all the water from the system and cause permanent damage to the engine. However, the Turkish authorities decided to override these objections and the first batch of twelve machines were converted with side radiators with the following aircraft to be fitted with leading edge types as per the Fokkers. The first Pfalz DXIII's were sent to the Caucasus Front to support an Ottoman advance towards Baku.
Mention has already been made in this thread of Dunsterforce. When the Russian revolution brought about the collapse of the Tsarist armed forces, British forces in Mesopotamia, advanced through modern Iran, and took control of the Russian area of influence in the north of the country. Turkish units had taken advantage of the withdrawal of the Russian army and were occupying the land east of the Caucasus Mts towards the Caspian Sea and the strategic oil fields. Dunsterforce was ordered to Baku to prevent the Ottomans gaining control of this asset. In this time line, the British force is reinforced by units from India. A flotilla of small gun boats is transferred overland to the Caspian by the Royal Navy and soon makes its presence felt. The Turkish advance on Baku is stymied but the Russian revolution has created four factions which are in a state of semi-permanent confrontation. With the Dardenalles still resolutely closed, the Entente sees the Caspian route as a means of getting supplies to the White Russian forces who are fighting the Bolsheviks. Since mid 1917 the British had seen the advantages of a railway connecting the Arabian Gulf to the Caspian Sea via Tehran. Post-war , they intended to make British influence permanent and were actively building a modern railway line. From Bandar-e Anzali shipping would transfer supplies and equipment to Baku and the Russian ports of Astrakhan and Petrovsk Port to the White Russian forces. To this end, a united Russian force capable of participating in the defence of this supply line had to be created. With British aid an unholy alliance was created whereby the Tsarist, Social Democrats and the Anarchists joined forces with Indian forces and attacked the Bolshevik faction. The local revolutionaries were part of a culture that had been fighting the Ottomans for centuries and were quick to change sides but the more idealogical cadres from the northern cities were rounded up and shot in typical Russian fashion. By the end of 1918 this hodgepotch force had managed to halt the Turks while the reinforced Dunsterforce attacked the flank from the south which resulted in a rapid retreat west.
One of the reasons for the success of the attack from the south was the total dominance of the air by the allied forces. The Ottoman air force on the Caucus' front had been decimated by a lack of spares and replacements. What aircraft remained in 1918 had been made good use of during the advance towards the Caspian Sea but by September only four early C types remained airworthy. The Russians had managed to keep a small unit of Voisin type pushers airworthy and another larger squadron comprised a dozen Farman F30's, another pusher design, with about 4-6 Nieuports as escorts. The British had two flights of RE8 reconnaisance aircraft, a third flying DH9's and a mixed fighter squadron flying Spad VII, Bristol monoplanes and a couple of Martinsyde Elephants. The Ottoman air units were knocked out within a couple of days and the allied aircraft ran riot with strafing attacks and information which allowed the Ottoman forces to be constantly out-manoeuvred in the field. It was into this scenario of total allied dominance that the newly formed Jagd Gruppe Kaucus was introduced during the early months of 1919.
As the re-equipment of the Ottoman air forces in the Middle East continued apace the older aircraft were sent to air parks in the rear. Those deemed suitable were refurbished and destined for training purposes or re-issue to other fronts. In the latter category, twelve Albatros CIII's and twelve Albatros DIII's became the core element of the new Kaucusus air units. Complemented by another flight of Albatros DVI fighters the Gruppe was despatched to the city of Van. Additional aircraft in the form of Pfalz XIII fighters and two captured DH4's supplemented by another two SE5a's were sent to Yerevan. Jagd Gruppe Kaucus began working up in preparation of the Spring offensive aimed at taking Baku. The Turkish commanders had appreciated the benefits the Anglo-Russian forces had gained by their total aerial supremacy and were determined to prevent such domination this year. To this end, they had requested a bias towards fighter aircraft within the air units to take on the allied reconnaissance machines which were in greater preponderance. When the offensive began the Ottoman units took a toll on these machines. The Russian Voisins had been replaced by British RE8's and operated along side the pusher Farman F30's. Both units suffered losses as did the RAF units. The British response was the Bristol Fighter which had been successfully employed in Palestine and helped to level the playing field. The Turkish offensive failed to reach Baku and the sides faced off for the final months before the war came to an end.
The Pfalz XIII is a conversion of the Classic Planes Pfalz X11 vacform. It's an early issue and lacking the now customary extras of strut material or such essentials as engines, machine guns and wheels.  I've already built the Eastern Express DXII and noticed that the vacform upper wing was slightly wider in chord. Which is right I don't know but I thought this would compensate for the narrower chord new wing, in effect it was going to be much like the Fokker DVII set up. So I used the vacfrom upper wing with a 10thou backing of card and increased the length of the surviving bits of lower wing from the Esci Fokker kit from the above posts. The vacform card has the Pfalz struts and undercarriage within it to use as templates and 20x30thou Evergreen strip was used for the struts. The kit fuselage was used as standard with a couple of card bulkheads to help solidify the halves when joined. Undercarriage is 35thou rod with resin wheels from the spares. Machine guns were leftovers from the Fokker Esci with the engine and exhaust combination another refugee from Fokker. The side radiators are from the same Heller sprues as the Fokker with the transfers representing the 2 staffel, number four aircraft with Balkan crosses and Ottoman black squares.
The initial equipment of the Jagd Gruppe Kaucus Jasta unit was comprised of the tropicalized Albatros DIII. This kit is real world but fits in nicely with this back story. The kit is an Extravac vacform which was issued by Hannants. It was obtained as part of a job lot of vacforms from eBay. There were eight kits and I already had two of them and there was this kit. As there are several good injection kits available I never envisaged building this type as a vacform. But I fancied a twin radiatored Middle East version and decided to experiment with the vacform wings. I also noticed that this kit had one of the best slab sided DIII fuselages I had seen so far. So, after creating a twin radiator centre-section from spare Roden parts to replace the vacform part, I continued building the rest of the kit. Hannants provided a resin engine, wheels, machine guns and an exhaust. There was no strut material but I had spare cabanes and interplanes from Roden kits. The prop was another spare from Roden but the spinner was cut from the card. Undercarriage was made from Evergreen rod and the axle spreader was a remnant from Airfix. The insignia are a mixture of Ottoman squares and Maltese crosses with the black stripe being the unit marking.
Fantastic back story for a terrific little model  :bow:  :bow:
Nice. The wood structure reminds of a Jaguar dashboard!
stevehed
Thanks Gentlemen, appreciated.
stevehed
Just getting a start with this. It was prompted when a stash inspection noted leftover bits of fuselage from the previous Fokker DVII projects. They were shorter than the original but plastic card could be used to stretch them to a usable length. A look through the wings box revealed a pair from an Albatros DV but that ship had already sailed. The only other complete set came from the Revell Boeing Kaydett, a 1920-30' s trainer. Being slighter wider chord and span than the originals would be a benefit when lugging a set of floats around, I thought, so the Brandenburg wing design started to evolve.
Other bits I've found among the spares are an exhaust stacks and cylinder head combo from a Hiero engine. This came from the MAC Phoenix D11 kit. According to the experts, most DVII's were to have the Hiero engine. MAG aircraft used the Austro-Daimler because the company were building it under licence. So the floatplane will use the Hiero which fits the contents of the spares box. Haven't decided whether to stay with the standard Fokker car radiator design or go for a leading edge radiator and streamlined nose. Floats are curtesy of KP who provide the option in their recently issued Avro 504 kits. I've got some bright orange N struts and a blue nose cowling from an Airfix Hannover. Debating on the prop but may use a four blade from the Airfix BE2c. Until it's painted it should look quite psychedelic.
The Fokker DVII had entered production before the end of 1918 and was destined to be one of the mainstays of the LFT fight force during 1919. The Hungarian MAG Company were furthest advanced with 25 completed and another 50 not far behind. The type was to enter operational service in Dec1918. Orders had been placed with Aviatik for 255 aircraft, 225 from Fokker, 150 from MAG and 30 from Thone and Fiala. The latter company was based in Vienna and had been involved in the ill fated Knoller reconnaissance aircraft but had latterly built 50 Aviatik D1 fighters under licence. A small company, they could not build the quantities the larger companies were capable of but there do not seem to have been any quality issues with the final product. As the war continued into 1919, the Thone and Fiala machines were redirected to the Naval bases around Trieste, on the Adriatic.
Most of the naval aerial conflict in this theatre of operations had been conducted with flying boat designs. At the moment, the Italians had the advantage with their Macchi M5, single seat flying boat fighter. The landplane Phoenix D types had been introduced to defend the naval bases but the AHN needed aircraft that could operate from water in the areas further south where land suitable for aerodromes was few and far between. The monoplane Hansa Brandenburg W29 two seater was one type selected and was being licence built by Ufag. The other type was to be a floatplane conversion of the Fokker DVII. Engineers from the Phoenix Company had adapted a wing design based on that used on the Hansa Brandenburg W12. Both companies were familiar with naval requirements and were owned by the same parent company which allowed free transfer of information between them. The resultant design was wireless and robust which reduced maintenance times.
stevehed
Been slowly prepping and drying fitting. The lower wing required plastic to be removed to make a cut out and the existing slot was widened. Floats were constructed, not the best fit but filler should improve the joints. Undercoat of grey followed by some Eastern Express lozenge. The fuselage is leftovers from the twin floater of a few years ago while the wing lozenge is from the EE Pfalz DXII. Not much good for France but the colours include a Mediterraean green which I hope will look the part. Progress so far.
 :thumbsup:  :thumbsup:
So far it's looking pretty sweet Steve ...looking forward to more  ;D
stevehed
#283
Thanks Gents. The Eastern Express lozenge was no bother at all. There wasn't enough for all the wings so I left the centre sections grey and later dabbed some Spanish blue on. The undersides are now HU121 stone which I like for clear doped linen. The nose was made from a Hannover cowling which I widened with a short length of strip on either side and added filler to the gaps. Shaped with a grinding wheel. MGs are just shaped plastic for the breeches and 20 thou rod for the long blast tubes favoured by the Austro-Hungarians. I'm using the Fokker tail plane but scratched a new fin and rudder with an extra fin on the underside. Red and white for a bit of colour. The cylinder heads are a good fit but lacked manifold pipes. I used a length of 30thou rod bent at each end and short pieces for the rest of the pipes. The floats are joined together with rod and ready to be installed. Tail next and then the top wing.
Looking sweet as a nut Steve  ;D  :thumbsup:
