He70 & BV141, blue : primary seaplanes
Started by ericr, April 23, 2015, 01:37:25 PM
I'd have never thought it was possible to make a Karas uglier, but.................  :banghead: :banghead:
ericr
Quote from: PR19_Kit on March 26, 2016, 09:08:45 AM
"sky" is the limit  :o
ericr
Quote from: ericr on March 26, 2016, 09:31:16 AM
by the way, in this case, it is of course not the floats that make it uglier  ;D
ericr
does anyone know a flying boat kit with waterline hull, like it is done for ships?
ericr
Quote from: ericr on March 26, 2016, 10:03:28 AM
I remember that there is this Fujimi Pete floatplane, as can be seen here : one side float and the main central one are proposed in waterline version :
http://www.model-making.eu/products/item_name-382873.html
see the pieces here
and the instructions at steps 6 and 7 (B type)
do you know any others ?
ericr
so I cut up a 1/48 Walrus from SMER, and triedto fit the hull to a Me 262, same scale (very good fit, sizewise), from Pegasus : here is the work in progress (with wings turned upsaide down to prevent water to come in the engines, of course)  :
I guess that is what is called kitbash ...  ;)
Quote from: ericr on March 29, 2016, 01:51:02 PM
Of course, yes! I LOVE our engineering way! Lift turned upside down for a technical good reason! :lol: ;D :thumbsup:
ericr
thanks!
I then realized that lateral visibility might be underoptimal ...  ;D
I changed the engines from under to over on the Revell 1/72 Luft '46 heavy fighter thingy by cutting the engine segment out, turning it over and mounting on the opposite  wing........this was to mount rear facing props for a turbo prop version.....
ericr
The result is very harmonious, congratulations. And a Me-262 without military evil signs seems a nice civilian worker (or tourist). ;)
ericr
thanks! it is indeed civilianized  ;D I prefer it like that
dumaniac
nice blue - appropriate for a seasplance
white crosses would make a nice contrast, if you did not want to go civilian
ericr
Quote from: dumaniac on April 04, 2016, 03:29:15 AM
thanks!
as I said, the shapes correspond with a good fit, at any scale,
so this combination can be tried with different liveries (RAF, Lftwaffe, or others) as you like  ;D
ericr
quite finished now, potentially carrying 4 seaplanes at a time ...
