Seaknight & M16, red : primary seaplanes
Started by ericr, April 23, 2015, 01:37:25 PM
Quote from: ericr on May 15, 2019, 11:36:49 AM
a flying boat conversion
(using a Canadair)
(I am trying to decrease my stash ...)
Great build,  I'm planning something similar  :banghead:
ericr
thanks !
please do make similar things and show them : others with more skills can do more  ;)
ericr
stash reduction continued, with waterline flying boats 1/350, and seaplanizations of two basic 1/144 kits ...
The F-19 is almost plausible with the intakes mounted on top of the fuselage like that. Are you aware of the Convair Sea Dart? A contemporary of the F-102 and F-106. Same wing IIRC with a floating fuselage and a couple of different experimental hydro ski arraignments. You may find it interesting.
The F-117 becoming a seaplane is marvelous! :wub:
And I thought it was nicknamed Blackhawk, would your one be the Bluehawk? :unsure: ;D
ericr
thanks !
yes I know the Sea Dart ( and the Mach 2 kit !)
both F117 and F19 do have that feeling, (but the F19 kit is just not as nice as the F117 ...)
The F-117ZW Twin-Bluehawk has the advantage to avoid the need of wingtip floats it seems. Still stealthy? :unsure: ;D
ericr
Blue Hawk brilliant,  that's another future build  :thumbsup:
ericr
some time ago I did a SB-17, with a rescue boat, hence a flying boat litterally.
Then I found a conversion kit for the SB-29, but in 1/48 : it was not easy to find the 1/48 B-29 cheap ...
So I opted for a 1/48 Ventura, looking close to the Hudson, which had a rescue boat version ...
ericr
thanks !
I cheated/whiffed a bit with the length of the rear gear to make it plausible ;)
Good, without the boat hurting the runway.
And the camouflage is also very plausible: invisible in a toy store! ;D
ericr
I made another one, with a Stirling I received as bonus when buying other kits, and a suitable boat I had to find
That would have made a lot of sense in the RW, the Stirling stood SO high off the ground that loading the lifeboat would have been a doddle compared to some of the other types that carried them, the B-17 for a starter.
And the colour scheme would have made it SO visible to the survivors too.  ;D
