avatar_lenny100
airifx valiant landing gear
Started by lenny100, May 14, 2015, 11:19:51 AM
lenny100
does anybody know how high the airfix Valiant landing gear is, I am looking at making a Gerry Anderson type aircraft and need long landing gear but with strength also as its a large cargo transporter
The distance between the axle pin and the tip of the locating pin is 42mm
1/72?  The main legs of the Italeri/Testors Boxcar are quite long.
Just make them out of tubes, insert the oleo into another tube with a slightly bigger ID. Should be plenty strong enough. And any length you wish !
