avatar_sandiego89
B-36 Crop duster- Finished *image reload last page*
Started by sandiego89, June 01, 2015, 03:44:57 AM
I've always wanted to build on of those, ASW or transport version. :thumbsup:
Wow! You could spray Luxembourg in a single pass!!
eatthis
is this bigger or smaller than the 48 scale b1b?
http://tinypic.com/m/hx3lmq/3
Quote from: eatthis on June 02, 2015, 01:33:51 AM
Depends on how you define "bigger"....If I have the math right (always questionable  ;)), the span of the 1/72 B-36 is greater than the (unswept) span of the 1/48 B-1B.  The B-1 is longer.
B-36 in 1/72: Span 38.3 inches, length 27 inches
B-1 in 1/48: Span 34.25 inches, length 36.5
Both kits are huge.  I have not seen the B-1 kit up close.
Quote from: sandiego89 on June 01, 2015, 06:42:49 PM
Thanks Rat!  I sure hope I can do it. Did I mention I fear natural metal finishes....
But dusters often have hi viz red/yellow/orange schemes as they're flying in close proximity to other dusters and they need to SEE each other.......  ;D
Quote from: sandiego89 on June 02, 2015, 05:29:57 AM
A friend had/built one (Revell 1:48 B-1B) many years ago - (really) HUGE thing, and the only option to stow it somewhere was to hang it upside down under the ceiling. Beware!
Martin H
got at least three of those monsters in my stash.....................................Ive no idea why, as ive got no where to put one built up let alone three.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
They're moulded so you can plug the wings in and out without glue. A bit like a carrier aircraft, you can almost fold it up.  ;D
#23
Quote from: PR19_Kit on June 02, 2015, 03:20:47 PM
Indeed.  Most aircraft kits have a wimpy tag to insert the wing into a fuselage slot, no such deal with this kit!   Here is the central wing spar section that goes through the fuselage and you slip both wings onto!
Work has begun.  The kit is a RB-36 with the short bomb bay, but I desire the long bomb bay, bomber version, with the two long bomb bays.  Will need to scratch up a bit of the bomb bay interior, and rescribe some bomb bay doors. Luckily the lumps and bumps and aerials of the RB version are add-ons, so just leaving them off gets you closer to the bomber versions.  Here you can see the "short" bomb bay that opened beneath bomb bays #2 and #3.  On most RB versions, bomb bay #1 was changed into a pressurized camera compartment, and #4 was used to mount radomes and hold other recon gear.
I have debated painting the entire plane more typical, vibrant, crop duster colors, but think the two tone magnesium and aluminum fits the backstory better.
Wish me luck boys.... Dave
At least have some brite yellow wingtips and panels! Please!
The Chaos
A very Big Aircraft Cool.  :thumbsup:
Glenn Gilbertson
Already I'm impressed!  :thumbsup: I remember the noise they made as they filled the sky in the 50s.
KiwiZac
Oooh this is insane, what a great idea!
Also I LOVE the Sea Fury!
Zac in NZ
https://linktr.ee/zacyates
Like the idea, mind you, what with the recent trend for doing fire bombers here -- and the real world trend for going with really big fire bombers, it wouldn't be much of a stretch going that route either ---
Gives me an idea for doing my XC-99  -------    :wacko:  :wacko:
I've got a mental image of a B-36 Fire bomber coming directly towards me across the surface of a lake filling its tanks.
It's a very pleasing image.
