avatar_Dizzyfugu
Hunting Percival P.26 Commuter (Martin B-26B Marauder) Aer Lingus, 1956 at p.8
Started by Dizzyfugu, June 02, 2015, 02:57:17 AM
I'm sure the paint or decal option will work just fine. With the flash paint job I don't think anybody will notice anyway....
In 1939 the R-3350 had not 'been around for some time', it was still under development. Look at columns 14 and 15
and you'll see that they are Turbo versions.
http://www.enginehistory.org/Wright/Wright%20R-3350.pdf
The first production Turbo-Compound R-3350 were delivered in March 1950, all production went to the military.
Commercial TC engines weren't produced until January 1952.
http://www.enginehistory.org/Wright/Cyclone18Facts.pdf
KiwiZac
Very cool! The new windows look great, and I just noticed the new wingtips.
Zac in NZ
https://linktr.ee/zacyates
Yesterday's evening saw the wings being mounted, and more body work. This Matchbox kit has several sinkholes and the fuselage halves somehow do not go together well, as if one side was a bit twisted. I also tried to engrave some emergency hatches, but that went wrong, so they were filled up again and I'll look for a decal solution.
BTW: the new wing tips change the look of the Marauder considerably - even though they do not add much to the span, maybe 1" on both sides! More dramatic than I expected. Also, the air intakes under the engines make them look more massive than the OOB radials, despite having more slender cowlings.
Landing gear is next, hopefully the CB-26 stands on its spindly legs this evening.
Looks somewhat sad from this perspective...?
Anyway, more to see. Dry-fitting of a wing before the fuselage was about to be glued together, as well as the OOB propeller:
"De/Militarize It" Group Build at whatifmodelers.com: a Martin Marauder Commuter (WiP) by dizzyfugu, on Flickr
Some details: the boarding ladder for the lower rear fuselage (scratched from styrene strips), and a selection of different wheels I will use - just for the sake of a slightly different look:
The interior:
...and the tail cone in place:
Logan Hartke
Quote from: Dizzyfugu on June 11, 2015, 09:53:02 AM
Has a bit of an Airspeed Ambassador look to it here.
Logan
Quote from: Logan Hartke on June 11, 2015, 10:06:36 AM
That's very true Logan, it sure has.  :thumbsup:
How about a triple fin then Thomas? That WILL confuse the JMNs.  ;D
Quote from: PR19_Kit on June 11, 2015, 11:12:35 AM
:thumbsup: :thumbsup: :thumbsup: :thumbsup:
loupgarou
The fuselage looks slimmer than the "usual" B-26. Another very good build, you have the capacity for finding continuously new and believable projects. :bow:
Quote from: Gondor on June 11, 2015, 12:27:36 PM
It does indeed.
Can't wait to see the full passenger cabin interior..
:wacko:
Well, you might be disappointed - I remain pragmatic and do only minimal interior work. The scratched cockpit was enough hustle, and I am currently trying to puzzle two figures together that look like a commercial crew...
I actually did a twin-fin ASW Marauder-thing many years ago (lent from an A-10, fit perfectly):
1:72 S-26 Maritime Patrol Bomber (whif/kit conversion) by dizzyfugu, on Flickr
I considered a similar conversion for this one, but I wanted to keep the B-26 outline. Compared with the Ambassador the CB-26 looks rather tubby. The windows create a treacherous cheatline, in fact I think the fuselage's diameter is a bit wider than on a benchmark Fokker 27, and the aircraft rests much higher over ground. Looks slick without all the guns, though, and I am curious how the solid nose looks with colors added?
As a side note: big surprise! The landing gear was dry yesterday evening, so I put the CB-26 on its feet to check ground attitude (placed the main legs a bit straighter, the new main wheels from an Il-28 bomber are a bit smaller than the OOB balloon tires)... and the thing keeps its nose down! Without extra weight! The resin engines are so big/massive/heavy that they are enough to keep the Marauder on its front leg - never expected that, especially after former experience with the Matchbox and Airfix kits...? The boarding ladder will be fixed in open position anyway, though, but that was one of the few moments that got me stunned...
Otherwise, not much happened. Landing gear covers were added, some antennae, detail sanding. Populating and closing the cockpit is next, and then things slowly move towards painting.
