avatar_JayBee
Fanera
Started by JayBee, June 02, 2015, 03:58:44 AM
Kit box picture for my second entry
Jim
And what a second entry, can't go wrong with such an oddity. :thumbsup:
What the devil is THAT Jim?   :o
I don't think I've ever seen one of them before, in any media.
Try this Kit
http://en.wikipedia.org/wiki/NIAI_LK-1
You will also find images of it in Google.
I have also seen, somewhere in the internet a clip of one taxying on skis.
It could ONLY be Russian Jim!  :o
Thanks for the link etc.  :thumbsup:
It is also a rather nice little kit. The fuselage "pod" is moulded in clear plastic, and you get a full set of masks with it.  :thumbsup:
Jim
Looking at that Wiki page, it's a lot smaller than I thought it was.
Modelling_Mushi
Quote from: JayBee on June 02, 2015, 03:58:44 AM
Has Tophe seen this one? Looks like he might have had a hand in its design  ;D
Should be fun.
Quote from: PR19_Kit on June 02, 2015, 07:25:59 AM
Welp, Westland also built an aircraft along similar lines. Not as succesful as the Soviet model.;D
Russian page on the Fanera, loads of photos:
http://www.airwar.ru/enc/cw1/fanera.html
Martin H
That westland looks far to conventional in the side view.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Freaky looking bird that's for sure !
The Chaos
WOW looks very cool.
Awesome Projekt.   :thumbsup:
Right, work has started on this one and there are a few changes required to the kit.
Firstly here is the text and three-view drawing from Bill Gunston's "Aircraft of the Soviet Union" dated 1983 from Osprey publishing.
If you read the text it says that seating within the aircraft was pilot and co-pilot left and right with two pasengers in the back.
The kit gives: pilot central with one seat to his right and three seats in the back.
I will be going for the text version.
Next comparing both the text and the three-view with the box art, the kit would appear to be one of the early test examples. Differences being :
Full span ailerons need to be changed to ailerons and flaps.
The Towend ring on the engine needs to go.
The shape of the fin and rudder should be changed if this is going to depict a production example, BUT I like the early rudder that the kit gives (Dilema!).
Finally, and this is not visible, the kit gives spats for the main wheels but for what I have in mind they have to go. Sorry BDB.
Onwards and upwards Comrades!
The kit is of the prototype/early variant.
http://airwar.ru/enc/cw1/fanera.html
If the pilot is sitting in the centre,  how does he see past the ruddy engine???  :unsure:
