avatar_McColm
AWACS and AEW &C camouflage schemes
Started by McColm, July 21, 2015, 11:20:26 PM
Quote from: McColm on July 25, 2015, 09:53:21 AM
That's worth Whiffing, seen the B-52 resin engines as an aftermarket kit in 1/144 and 1/72 scale.
Unless you use the earlier engine type you will be doing it wrong, look carefully at the engines in the picture, you will notice a slight bulge under at least one of them which is only there on the versions prior to the G/H versions of the B-52.
My build would be different as I'm using a EC-135 Snoopy as the donor aircraft.
That is so cool. I'll have to check the weights and powers of both a/c and engines....just seems like a lot of power for a 707 type to me ? Still looks pretty wild and a model would be sure to turn some heads.
Cutting Edge Modelworks do a NASA mother ship conversion for the B-52G/H so it's feasible to build
Speaking of AEW camouflage colours.  Does anybody know where I can get a hold of "RAF Blue Grey BSC361C" for use on RN FAA Gannets in the late 1960s, early 1970s?  Or something that is a near equivalent?
When I look up BSC361 it comes up as Light Stone  :blink: Are you sure of your reference and have you tried here?
Quote from: Gondor on July 31, 2015, 05:52:42 AM
It states "BSC361" on the decal instructions from Xtradecal.   I note there is also a "633" next to it, which according to the IPMS charts translates to FS:16044 which looks right on my screen.   It appears Xtracolor makes it as X013.  Unfortunately only in an enamel.  I prefer acrylic paints myself.
BS381c #633 is indeed RAF Blue grey.
BS381c is one of the British colour standard documents.
The iModelkit iPhone and iPad app gives a direct match of Akan 80 039 enamel.
Going from FS, 26044 (no 16044) is matched to Vallejo 70.995 German Grey acrylic.
http://www.imodelkit.com/id6_WebSite_en/iModelKit.html
Quote from: rickshaw on July 31, 2015, 04:57:56 AM
Those are COD4 Gannets, AEW Gannets were Extra Dark Sea Grey over Sky.
See what Italeri or Revell used for their Wessex HAS3 as thats the same colour as the Gannet COD
TallEng
Look on Hannants they've got RAF Blue grey in their Xtracolor range
See here http://www.hannants.co.uk/search/?search_direction=asc&search=Xtracolor%20&manufacturer_id=8272
Or you could try the IPMS Stockholm site which has loads of info on colours
And model paint matches http://www.ipmsstockholm.org/colorcharts/colorcharts.asp
Keith
Thanks, one and all, I've ordered some Vallejo 70.995 German Grey.
Quote from: Gondor on July 25, 2015, 07:54:29 AM
Quote from: Captain Canada on July 25, 2015, 05:09:27 AM
Oh that is lovely ! That is what I meant. Not necessarily operating down low, just blending in down low  :thumbsup:
That picture shows it landing/taking off and I remember seeing pictures of the EC-121 in camouflage during Vietnam as well.
The EC-121R was painted in the USAF "SEA" camo colour scheme.
Quote from: McColm on July 31, 2015, 11:04:07 PM
And because that was the case they probably decided that drawing the proposal in SEA camo would be apt.
Wow, I never knew about the 707/135 with the 8 engine proposal. Great looking WHIF.
