avatar_McColm
Chinese Stealth Fighter H-20 or is it?
Started by McColm, August 12, 2015, 08:55:02 PM
Images of the leaked Chinese stealth fighter the H-20 appear to be a cross between a Su-24 and F-22.
Whilst previous images suggest a kitbash between the F-117, B-2 and YF-23.
Makes for an interesting build, although the wing looks more F-101 to me.
The Su-34 might be a better donor kit by moving the engine air intakes in-line on the upper fuselage above the wing joint. B-2 style air intakes.
No, that's a different design. The J-20 is available in 1:144 an 1:72, but the "H-20" (ar whatever, AFAIK there's no confirmed designation yet), and this attack aircraft rather looks like a Su-34 nose grated onto an YF-23, with wings that truly remind of the F-101.
Here's artwork from theavionist.com:
http://theaviationist.com/2015/04/03/china-new-lrs-artwork/
It's not new, though, has been around since at least 2013:
More here: http://theaviationist.com/2013/06/11/china-lrs/
seadude
It's so scary when I see China, Russia, or some other country copying U.S. designs of stuff. Makes me think we're not doing enough security-wise to prevent espionage.  :banghead:
You have to remember that most designs are generated via computer nowadays (and for years since) and that given the input parametres computers are likely to come up with very, very similar looking designs
At least SOMEONE'S using the F-23 design, which is more than the dumbheads in the USAF did...........
Thanks for the info, Dizzy! I only did a quick search of H-20 and only the J-20 came up, i'd never seen that one before. :thumbsup:
I do like the design, very nice mix of ideas in that.
Besides the obvious F-23 main fuselage with SU-24 cockpit, the wings are the same as the MDD Joint Strike Fighter proposed design but i agree that, it looks a lot like the F-101's wing too.
But to build a model of that, the wing would be a hard choice for me. If i was to build such a thing, i'd probably use the F-23's complete fuselage and even use part of the wing and scratch-build the rest, the intakes would't be too hard to attach to the upper fuselage and link it to the engines. The cockpit would definitely have to be SU-24.
You could use the 1/72 F-19 engine air intakes and parts to the Su-34,F-23,F-101 kitbash.e
Quote from: PR19_Kit on August 13, 2015, 07:44:11 AM
I'll still blame that on Lockheed shenanigans, Kit
Jesse220
KJ_Lesnick
Side-by-side seating looks attack/bomber ish
If its H then its a Strike Bomber as J is the prefix for Chinese Fighter types.
Its the J-20 crossed with the Su-34 concept and probably not a great deal far away from the Avpro FOAS that Falcon built
The first shot looks great. Looks easy enough to copy, well, if you don`t want an exact copy  :thumbsup:
