The Black Mamba
Started by Glenn, October 21, 2004, 06:49:43 PM
Glenn
With the success of the Bomarc project, Boeing developed a larger rocket, but this time, a manned project. Still launched from a platform the Black Mamba was designed purely to intercept Tu-4's and later Tu-16's flying over US airspace. Most were housed in silo's in Alaska guarding NORAD.
Seen here as part of the test program after it's launch from Edwards.
Model : Revell Bomarc IM-99 (1/52nd sc.)
Finished : 1/72 SAC interceptor.
Rocket burn, Adobe to remove the wire holding the model.
Shasper
- Bud S.
Sweet !
I hear that Bomarc kit is rare and quite pricey...nice to see her chopped up built proper !
:wub:  :wub:  :wub:
Nice model :wub: , and incredible photograph as usual. In a trial, this could stand as a very proof: "look, it actually exists"... :)
Green question: why is the smoke for the above engine only? chemical rocket there and simple turbojet below? or afterburner above?
Swamphen
Quotewhy is the smoke for the above engine only? chemical rocket there and simple turbojet below? or afterburner above?
Evan can correct me if I'm wrong  ;)  but the rocket is in the tail; underneath is a ramjet, which only starts up after the rocket burns out.
Great model Glenn!!  :wub:  :wub:
Two for me, please.  Just like yours----LOVE it!
Gary
Very neat conceptually. Kinda reminds me of the Natter.
Getting back into modeling
Shasper
Da, I agree w/ Wook.
Ves B)
- Bud S.
TsrJoe
sweet  :wub: ...have you been looking through circa late 1950's issues of 'Flight'? i recall one issue actually showed a speculative design virtually identical to what youv realised in model form...really cool
happy what'iffing, cheers, joe  :ph34r:
WeeJimmy
That's why Deifenbaker bought them...  someone reneged on the full deal ;)
Swamphen
QuoteI think Nev's right about the ramjet
Oi!  ;)
elmayerle
You're correct.  Take the Bomarc, it has two ramjets, one under each wing, but launches with the rocket housed internally.
--Jane Wagner and Lily Tomlin
Quotethe ramjet - like pulsejets - need forward motion to be able to start.  You can't start "cold" as it were, hence all the Luft '46 ramjet projects having a rocket engine for takeoff.
:unsure: Uh, should I look in my books, or will JCC have all in his mind? The French Griffon prototype (or Griffon II, I don't remember) was having a turbo-ramjet, able to start by itself (tiny turbojet inside, if my memory is right) then using ramjet only (turbo stopped?) for supersonic cruise... :)
Somehow, this may be just a word-game, I don't know, as a classical afterburner is a kind of ramjet behind a turbojet... :)
More interesting: a missile (from AĆ©rospatiale?) used a rocket and central chemicals tanks for it, to start and increase speed, then when all the chemicals had burnt, air intakes opened and the disappeared chemicals had made room for a ramjet pipe. I don't remember the name of this device (statomixte in French? combi-ramjet?), nor the missile name (ASMP?) but I remember that the engineers were very proud of it. :)
elmayerle
The Griffon II (the Griffon I was a tail-sitter of similar concept) used a turbojet (ATAR 101, I believe) for take-off, landing, & low-speed flight and converted to ramjet power in flight; the ramjet in this case wrapping around the turbojet.  The Republic F-103 would've used a similar concept, though it had the two engines in parallel.  I believe the missile you're discussing is the ASMP, though the Russians have several similar ones including the Kh-41.  All of these are integral-rocket-ramjets where the initial launch impetus is provided by rockets which bring the missile up to a speed where the ramjet can function for the remainder of the flight.  Generally the "rocket-only" portion of the propulsion section is a solid fuel mix of fuel and oxidizer which transitions to a mix of fuel with a little oxidizer for ramjet operation, the fuel that doesn't burn with the oxidizer being burned with the incoming air for propulsion.  The US has conducted tests of this concept, the Vought ALVRJ for example, and it has figured in some proposals like Northrop's stealthy ND-1 which carried a submunitions dispenser.
