avatar_zenrat
Armstrong Whitworth Lamington
Started by zenrat, November 12, 2015, 12:54:38 AM
The Lamington.  Not the delicious coconut dusted cube of cakey goodness but the Armstrong Whitworth high altitude photo reconnaissance aircraft.
I have just fitted the Napier Cutlass Inverted Vee 12 opposed cylinder two stroke heavy oil engine.  The turbo chargers will be installed behind the engine.
If that's meant to fly at high altitude it's going to need MUCH longer wings!!!
perttime
Interesting...
I was thinking that the front end looks long and heavy  :unsure:
Interesting... what is/are the basis kit(s) you used?
Quote from: PR19_Kit on November 12, 2015, 07:42:33 AM
So you don't think they are long enough as they are?
Lucky then I have some nice long wings to add which will increase the span by approx 50%.
Tophe - the fuselage is an ARK models Dewoitine D520.  It's repopped from Frog moulds and somehow in the process the underside centre section appears to have shrunk slightly because there is a significant gap at the front (assuming it fitted when Frog were making them which might be foolish).  The engine is from an Academy Ju-87G.  In reality the Napier Cutlass, being a downsized Napier Culverin (which was itself a license built Junkers Jumo 204) was a twin crank, six cylinder, 12 piston inline engine which existed in prototype form only.  Of course in Whiff world it can be whatever I want it to be and so becomes a 3 crank, 12 cylinder, 24 piston Vee engine.  I would have made it a deltic but the cowling isn't wide enough across the base.
Pertime - I made it long at the front 1) to allow room for turbos in the fuselage behind the engine and 2) to exaggerate the rearward set cockpit design.  Also, the wings I will be attaching have a greater root chord than standard and I will be lining up the trailing edges.
Quote from: zenrat on November 13, 2015, 12:23:04 AM
As they are in the pic I think the wing loading would be a tad high.  ;D
Even a 50% increase won't help too much, but maybe you meant a 50% increase on the Dw 520's standard wings? That sounds much more plausible.
Love it so far ! At first I thought it was the engine/ nose from a P-6E, but that's not inverted. Also intrigued by the 2-stroke !
There are more 2 stroke diesels than you'd think.  IIRC the big Detroit Diesel truck engines are 2 strokes.
... and the great majority of US railroad diesels are 2 strokes as well. As EMD exported a bunch of them to the UK, albeit shrunk to fit our small railway, there's a lot over here too.
[A bit later] IIRC opposed piston diesels have to be 2 strokes too, as any valve gear, other than sleeve valves, would be incredibly complex. Which means the Fairbanks-Morse diesels on WWII USN submarines were 2 strokes as well.
Yes, of course <slaps forehead> i'd forgotten about the valve gear issue.
When you say two stroke normal people tend to think of the small stinky motors in mopeds and whipper snippers.
I am ashamed I have not recognized the D520 (which is the local hero in my country), but now that you say it, this is very obvious, thanks! And congratulations again!
Quote from: zenrat on November 13, 2015, 11:23:12 PM
This particular person thinks of abominable devices for converting fuel into noise......motion is merely a side effect
Quote from: Rheged on November 14, 2015, 01:45:50 AM
....................and smoke.
Quote from: PR19_Kit on November 14, 2015, 02:18:41 AM
I've had a few 2 stroke bikes which fit that description.
This one sounded like a chain saw...
...and this one smoked like a bustard.
This one attracted small children...
...and this one their father (Captain Fat Hamster).
But they were all fun.
Long live the 2-stroke ! I'll have to read into more of the big diesels etc.
