avatar_zenrat
63' HSGB
Started by zenrat, November 13, 2015, 11:54:06 PM
I've started a floaty thing.
Airfix RAF Rescue Launch which I am repurposing to anti invasion duties with more guns.
You teaser... will you tell us more? ;)
(probably yes someday but soon would be good)
tigercat
I plan to replace one of single gun turrets with a multi gun one from a heavy bomber and emplace a dual purpose gun into the front bit of deck (is that the fo'c's'le?).
So far I have glued the halves of the hull together and today attached the rather ill fitting transom.
<later>  Foredeck not fo'c's'le.
tigercat
A High speed monitor ? Not that I'm trying to give you ideas. Adjust halo.
High Speed Gun Boat.  Smaller and faster then the Dog Boats & Fairmile C's but with lighter armament.  Ideal for getting in amongst barges being towed across the channel.  I had thought about using a quad 50 mount from a Matchbox M16 half track but decided to use something else I had in my stash already.
More likely to be a quad or octet of 2pdr Pom-Poms - enough to spoil anyone's day !
Nice idea looking forward to seeing it !
So, now the Hs 127 & Pamplemousse are finished I shall get on with the floaty thing.
Here's where i'm at so far.  I've removed the stowed scramble nets from the rear sides of the deck, drilled a hole for the new front gun and built a breakwater to keep the sea away from the gun.
This now has a wheelhouse and the rest of the superstructure is coming along but will I finish in 10 days?
Probably not.
Never mind, i've been thinking it'd look good as a PDRV Revenue Protection vessel...
