avatar_Modelling_Mushi
Bear Professional Painters Masking Tape = Tamiya Tape?
Started by Modelling_Mushi, January 11, 2016, 11:07:27 PM
Modelling_Mushi
Came across this stuff at Bunnings yesterday:
I've had a quick look and for all intents it seems the same as Tamya tape; same feel, tack, paper etc. I bough this roll (36mm x 50m) and a second (24mm x 50m) for $10 to $15 each, so I figure it's a bit cheaper than the Tamiya stuff.
Will be using it in the next month or so, will let you know how it goes.
Ciao
Thanks Mushi.
I usually use the low tack blue scotch masking tape from the "B" word but i'll check this out net time i'm in there.
Don't suppose they go down to useful widths like 6mm?
Modelling_Mushi
Sorry ZR, not to 6mm. Thinnest I saw was the 24mm at Bunnings. Nortons website lists an 18mm but I've not seen it.
Thanks Mushi.  I can't think why you'd want 6mm tape for reno use but you never know...
Modelling_Mushi
Hello all
It's been a while now and I have given this stuff a good workout so I know what it can (and can't) do. First off, don't throw away your Tamiya tape if you use it!
Advantages / What it can do
  • Dead cheap. So that helps.
  • Low tack. Tried it over paint applied by brush and airbrushed on unprepped, washed bare plastic, and washed / prepped / primed painted surfaces in acrylic (Gunze & Tamiya) and enamel (MM and Humbrol) and no lift off at all. Left it on for 3 days after spraying, no lift off at all, no residue.
  • Clean edge. Applied, added a slight hit of Future / Paast and then sprayed over it, left a nice clean edge with no bleed through.
  • No bleed through. Sprayed and brush painted to 'Moses flood level', no bleed through the tape at all
  • Flats and gentle contours adheres well. Stays put on flat and mildly undulating (wings, fuselage, bodywork) plastic.
Disadvantages / What it can't do
  • Tight curves. Lifts badly if left to its own devices on very curved sufraces (jet intakes, wheel edges, missile bodies
  • Can be a bugger to cut. Caught me out this one, but it can be a bit tricky to get through with scissors. No issues with a knife.
How I am going to use it
Works best when I use Tamiya or a similar proprietary tape to define the edges, then use this one the fill in the gaps between the Tamiya tape boundaries. A quick run over with Future or Paast on the tape helps it adhere well to the Tamiya and gets no lifting. It has replaced my usual 'bulk filler' mask (post it notes, Tamiya tape or thelike) and replaced any masking at all on flat surfaces.
Hope this is helpful,
Ciao
