SEPECAT Cheetah (like a Jaguar, only faster)
Started by Devilfish, March 21, 2016, 12:23:37 AM
Cheetah 2.0 is on the bench! Progress is fast, and I found out that the plan for this conversion must have been on the list for while because I found four(!) Heller Jaguars in the stash, each actually bought for this conversion... ;) Well, enough fodder for a maritime version, though...
Progress will be posted under the Cold War GB.
If you don't mind I'll use the "Cheetah" designation for my build, too?
Quote from: Gondor on April 02, 2016, 06:16:32 AM
Quote from: zenrat on April 02, 2016, 05:16:26 AM
I was looking at the cutaway drawing of a Jag in my Encyclopaedia of Combat Aircraft today.  Did they all have an arrestor hook?  The drawing, which purports to be a GR1 shows one.
Short answer "Yes"
It was for the airfield arresting system installed at some airfields by the RAF. I remember seeing some pictures of some aircraft, either Jaguars of Phantoms in the 70's using the system in Germany but I don't remember any details, sorry  :-\
Thanks.
Raptormodeller
Certainly looks the part, looking forward to the finished post...
A raptor with a difference
Whiffs are life                                            I found vis on vi intarnat i down noh
the worlds ONLY modelling raptor               whow toow speel
Leading Observer
Quote from: Devilfish on March 23, 2016, 03:30:17 AM
To me the M's undercarriage looks completely different.
Although, to simplify things, I will probably use the original main legs.  I'll look for a replacement nose leg, and I have the wheels/tyres off the Tornado.
It is different:https://uk.pinterest.com/pin/340232946821889561/
LO
Quote from: zenrat on April 02, 2016, 09:34:30 PM
Short answer "Yes"
Thanks.
Many land-based NATO aircraft had and have a hook, e .g. the F-104, the F-16, even Belgian Mirage 5s.
Devilfish
Managed to get a bit more done this weekend.  Much sanding and a coat of paint, then found some decals. 892 sqn, "Omega"
Devilfish
Short answer "Yes"
Confirmed yes, but it was I believe a "one shot" spring loaded light duty hook, for runway emergency use. Needs to be beefed up for carrier use
TallEng
Grrr! 892 NAS
Please dont use the Omega insignia.
see here for details https://en.wikipedia.org/wiki/892_Naval_Air_Squadron
Keith.
Devilfish
Quote from: TallEng on April 03, 2016, 11:28:24 PM
Grrr! 892 NAS
Keith.
I know it's not their "official" marking, but it was all I could find that was suitable, so I have used it with the story that they have carried on using it as a homage to the Phantom unit.
Quote from: Dizzyfugu on April 03, 2016, 08:49:21 AM
Short answer "Yes"
Thanks.
Quote from: Devilfish on April 03, 2016, 11:13:17 PM
Short answer "Yes"
How about that.  You learn something new every day.  Thanks guys.
KiwiZac
Zac in NZ
https://linktr.ee/zacyates
bearmatt
The carpet monster took it!
In the meantime, a direct concept comparison:
SEPECAT Cheetah GR.2 (Kitbashing) - WiP by dizzyfugu, on Flickr
The same, but not identical...  ;)
