avatar_Gondor
60 Sqn Lightning F6 VGA
Started by Gondor, March 31, 2016, 02:28:03 PM
Is that enough weight?
Looks nice.
Quote from: zenrat on September 23, 2017, 07:06:23 PM
Looks nice.
Yes it is after the nose cone was filled with weight as well
I did have some problems getting the windscreen to fit as the combing had not fitted correctly. My fault probably but at least I know to look out for that with my next Lightening.
Thinking of modelling the canopy open as I have more than likely messed up positioning the windscreen. The canopy is nice and clear so you can see all the effort I put into the seat even with it closed.
That's looking better and better Alastair.  :thumbsup:
Quote from: PR19_Kit on September 24, 2017, 03:15:02 PM
Yup, impressive "metal work"  :thumbsup:
A little bit of painting carried out tonight. Black was applied over the windscreen joint as well as for the anti dazzle panel on the nose. A touch of black was also added to the edges of the canopy to improve it's look for when the canopy is fitted in the open position. Decals should be next, the stencils first then squadron markings and finally the undercarriage doors, missiles as well as the intake blanking plate and pitot tube.
KiwiZac
That's looking super sharp. Nice work Alastair!
Zac in NZ
https://linktr.ee/zacyates
Not looking quite as good as I hoped after masking the anti-glare panel. Touching up the paintwork will have to be done using Hu33 and Hu11, the latter looking close to the rattle tin silver that I used on the aircraft.
Onwards and upwards as they say.
You can get away with a different shade on the nose ring.
Quote from: The Wooksta! on September 26, 2017, 04:05:12 PM
It is Lee, just doesn't show up well in the pictures. Hu191 as per the instructions
I think that I have all the detail painting done now, well apart from navigation lights  :rolleyes:
Next up will be decalling, or rather preparing for decalling. Having used the Halfords Aluminium paint do I have to use a varnish prior to using the decals and if so is Klear ok or will I have to use something else?
I've found that the old style Klear works fine over any Halfords paint, but I can't speak for the new version. Best try a test part first I think.
That sure is looking good. Nice work. Love the Lightning VGA ideas !
Quote from: PR19_Kit on September 30, 2017, 11:59:41 AM
I think there are a few bits of sprue or something that I can test the Klear on first  :thumbsup:
Here is a quick picture of the nose of the aircraft along with a section of sprue with the flaps from the kit's wings which as they are not being used in this build and having gotten some over-spray are ideal to test some Klear on which I have done, I will see what the result is in the morning.
This should be finished in time for Glasgow in almost three weeks time.
