avatar_Old Wombat
RAM F6F-3 Hellcat 1/48 - Finished - Pic's pg.2
Started by Old Wombat, May 16, 2016, 07:24:14 PM
OK, this is going to be my primary build for this GB.
Mostly OoB with a few detail bits & a scheme based loosely on PantherG's RAAF scheme.
What I'm starting with:
Boxed immediately after this photo was taken:
In a scheme loosely based on these:
Just waiting for the starting gun! ;D
Quite a striking colour scheme........have you any idea what manufacturer paints and respective numbers you will use...?
Not exactly the same colours & only 3 of them, with the intermediate blue wrapping around onto the undersides.
I'm using Lifecolor acrylics for all of them;
UA 052 (FS 34079) Dark Green
UA 045 (FS 35164) Non-Specular Intermediate Blue
UA 044 (FS 35042) Non-Specular Sea Blue
I went with the UA 052 because:
a) my preferred supplier didn't have UA 008 (FS 34092) Medium Green 1942 in stock;
b) FS 34092 didn't look close enough to Australian foliage greens but UA 052 does look reasonably close to one version, &;
c) I had it in stock in my paint drawer.
Quote from: Old Wombat on May 17, 2016, 07:52:24 AM
Always a good reason I find  ;D
Lifecolor do two sets of "authentic" RAAF WWII colours. Got them both and they have come in very handy and continue to do so.
Unfortunately I don't seem to be able to find the foliage green (UA 514) as an individual colour & I don't really want the set (although I may buy it in the future, if I feel I need more than 1 colour).
I just popped into the model room to see what the number was on the Foliage Green but as you say they have used a number that, as far as I can tell, is not available individually.
I like Lifecolor as a paint so have a few of their sets. The Italian one is very useful.
Thanks for the info and for taking the time to reply...... :thumbsup:
Movement: miniscule
Satisfaction: high (with acheived goals)
Yep, I've only really done the engine but I'm happy with the results.
I'm using an Eduard detailing set for the cockpit &, as this is the 1st time I've ever tried this kind of thing, I'm struggling with the level of forward planning it involves.
Still, ya gotta try to learn. :thumbsup:
Lots of parts there ! Looks like a nice kit. Great start on her !
Since my last post on the F4D-1P Spyray I've put it aside & returned to this build, finally confronting my fear of all the fiddly little detaily Eduard PE I bought for the cockpit (This is my 1st use of this level of PE detailing sets).
So far ... Not too bad! :lol:
I've found that PE pieces of all sizes will ping off into the wild blue yonder for no apparent reason & some of the placement indicators are a bit too vague (I've spend 3 hours of the last 3 days modelling time hunting down wayward parts <Haven't lost one .... Yet!> & about 1.5 hours juggling 2 pieces so that they look OK because the instruction positions are impossible to replicate).
Overall, I must say I'm highly impressed with the detail (although some elements do lack a bit of depth) & the unexpected ease with which they go together, especially the 2-part instrument panels.
Anyway, photo's sometime in the next few days, I think.
I use the Eduard 1/72 Zoom PE sets on some of my builds, at least I use the bits you will see (or I can see  :o) and I cut them from the frame inside a clear plastic bag of the sort they come in but a little larger. If the do ping then they stay in the bag unless it's really not your day.
If you like the Eduard instrument panels then have a look at the Yahu one piece ones. No assembly, inexpensive and really do just slot into place. I've only used the 1/72 ones but they are a very simple improvement to a most kits.
Here's the 1/48 ones
https://www.hannants.co.uk/search/?product_category_id=0&product_division_id=0&scale_id=955&product_type_id=0&manufacturer_id=362606&search_direction=asc
loupgarou
Quote from: NARSES2 on July 28, 2016, 06:30:35 AM
TWO nice tips in ONE post. Thanks a lot. Will try to emember and follow. :thumbsup:
So, photo's of the cockpit. There are quite a few of them & they show how appalling my build of this is - up really, really close. With normal eyeball view it looks pretty good - a bit rough in spots due to fit problems & those damned vague instructions, again.
Anyway, here are the pic's:
It's all been wrapped up, now, as I've glued the fuselage together &, hopefully, things will move a little faster.
