avatar_Old Wombat
NARDU F4D-1P Spyray 1/48 - Finished - pic's pg.4
Started by Old Wombat, May 16, 2016, 07:48:27 PM
My second (optional) build is going to be a F4D-1 modified with a PR nose from another kit.
Idea is that the RAN purchased a four of these aircraft in the early 1960's for evaluation purposes to replace their F9F-8's but opted for the F-8 Crusader, instead.
The Naval Aircraft Research & Development Unit (NARDU), the RAN's version of its RAAF equivalent, retained these aircraft for weapons, stores pylon & targetting system testing.
In the mid-70's three of these aircraft were retired & used for parts to keep the 4th flying.
This aircraft was modified by fitting a PR nose to the airframe & was used as a chase-plane to record test flights of other aircraft & the effectiveness of weapons delivery systems.
It was scrapped in 1984 after a crash-landing at NAS Parafield, SA.
What I'm starting with:
Still waiting for the starters gun! ;D
Sounds great......excuse my ignorance but, is that a podded IFR probe.....?  Fixed extended like that....?  Or does it slide back in the tank....?  I have seen a modern item on an F16 that folds out of a wing mounted tank......so it can be fuelled both ways.......
Fixed IFR - it's surprising how old this design is, really (first flight Jan 1951, introduced into service 1956)
Quote from: airvectors.netAlthough the Skyray didn't have inflight refueling capabilities itself, it could carry external tanks with nose probes for hose-and-drogue refueling. Very few photographs show this fit, however, and though it was said to have been approved for service, it doesn't seem to have been widely used.
http://www.airvectors.net/avskyray.html
The airvectors write-up by Greg Goebel is quite an interesting read.
Which PR nose are you planning to graft onto it?
Quote from: PR19_Kit on May 17, 2016, 10:40:13 AM
The one in the photo?! ;)
Quote from: Old Wombat on May 17, 2016, 10:41:39 AM
Ok, but what's it from? I don't recognise it I'm afraid.
Oh, alright, then! :rolleyes:
It's the optional PR nose from my KittyHawk F9F-8/8P kit.
It'll need a bit of slicing & dicing & PSR to fit but not too much.
Ahah, so it's 1/48 scale then.
That's why I didn't recognise it, bit sounds like it should go well on a Skyray.
Ooh! :o
Title fix to end confusion! :thumbsup:
The Skyray is a very attractive aircraft.
Here's one I "drew" earlier with an F9F-6P nose.
I now have an AMT (Airfix) Banshee which has the photo nose so if I can lay my hands on another 1/72 Tamiya Skyray...
Looking forward to seeing this one ! Love that aeroplane.
Right, so a start has been made. :thumbsup:
Not huge progress but it is moving. I've painted & put together the photo-recce gear & put it in the main body of the PR nose. To finish this bit I have to glue the glazing into the other 3 panels & fit them to the body-work.
In a fit of misplaced enthusiasm I glued the nose to the cockpit section; :banghead:
In this shot we have the original F4D-1 nose for comparison;
So, next job is to remove it & work on the cockpit. :rolleyes:
Very nice. Love the shape and the details look great !
