avatar_Army of One
Westernised Ka50 Hokum......
Started by Army of One, May 22, 2016, 01:49:42 PM
Not the clearest pic but........this is how i attempted the join. The rotor was cut at the hinge and then a groove was sanded so it slipped over the the stump on the rotor head. Not the strongest joint but i may have to build a simple brace similar to the ones i have seen used on the real thing.....well, the Ka52.......
Work on the nose optics.......seems a bit big......thoughts anyone before it is glued....? The unit is glued together but it is just sat on the platform at the moment......
Maybe reverse the nose and hang it below? Looks a bit tall and stalky, and a fairing would probaböy not help much?
Ah.......the Sea Spray style radar housing  (Lynx HMA8 style) is going underneath........maybe fashion another one using smaller components......
Quickly knocked up a second unit........any thoughts anyone....?  To be mounted on the top part of the nose......
The only thing I'd mention is the supporting arms look a little 'lite'.
They're usually quite substantial on a FLIR turret and wrap around:
http://smnzone.scalemodellingno.netdna-cdn.com/wp-content/gallery/airfix-westland-lynx-hma-8-hn/1b-hn-ac-airfix-westland-lynx-hma-8-1-48.jpg
http://www.flir.com/uploadedImages/Shared/Images/Products/Legacy/Sea%20Star%20SAFIRE%20II.jpg
I think I may have the bits still around from the Airfix Lynx, if I can find them would you like them?
Quote from: Mossie on July 05, 2016, 01:32:08 AM
A very kind offer......many thanks.....yes please.......you need me to pm you my details....?
Nice. I'd go with either. Or just add a bit of 'beef' the bottom of the second one. But it sounds like problem solved anyway !
Quote from: Army of One on July 05, 2016, 12:00:57 PM
Found them!  Yes, PM me and I'll pop them in the post.
Joe C-P
Quote from: Army of One on July 01, 2016, 03:14:59 AM
I can recommend using a pin vise and a small drill to make a hole through both parts, and then a small brass or steel rod/wire, which will both align and give strength. I did this for a helicopter model I built.
