avatar_Supertom
SITE MIGRATION COMPLETED - Post issues here
Started by Supertom, July 18, 2016, 08:39:35 AM
Quote from: Weaver on July 22, 2016, 08:01:03 AM
...Smileys are supposed to express your feelings: I've honestly never felt 'tank'.......
There have been times when I have felt i'd like to drive a tank over certain people...
The new arrangements look good.  I have no complaints, niggles or problems (other than the usual ones relating to life in general) and everything appears to be working OK.
Thanks guys.
overscan
Email seems to be working - I got a notification.
Paul Martell-Mead / Overscan
"What if?" addict
Quote from: overscan on July 22, 2016, 11:29:23 PM
Yeap got one too so looks OK
The forum time is 8 hours out:
Current forum time: 23-07-2016, 01:44:50  <- that's the time before any time zone offset, and I'm writing this at 09:44 GMT
overscan
Hobbes, check your time offset in Profile - Look and Layout. You are set to 1 hour offset. Server is running in Los Angeles time, so unless you moved country recently that is wrong - just hit "auto detect" to fix it.  :lol:
"What if?" addict
overscan
Edge fix has been implemented. Its not thoroughly tested. You will need to clear your Edge browser cache to ensure you get the new code.
"What if?" addict
loupgarou
Quote from: overscan on July 23, 2016, 02:02:53 AM
I have the same "problem", even if it's not important at all.
I hit auto detect, now it tells me I have a 9 hours offset, but I still see the Los Angeles time.
overscan
Current forum time: in the profile page should always show the current time on server e.g. Current forum time: July 23, 2016, 02:13:25 am right now.
If you return to main index after setting an offset your posts should now have correct local times.
You may need to clear browser cache or something?
"What if?" addict
loupgarou
Quote from: overscan on July 23, 2016, 02:13:16 AM
Thanks. Probably it's the server cache. I suppose it will clear soon or later.
I assumed 'forum time' would be GMT, hadn't considered the server might be located somewhere else...
thanks!
overscan
"What if?" addict
overscan
Quote from: Hobbes on July 23, 2016, 02:33:05 AM
thanks!
Well, old server was US too. US is cheaper for hosting. NZ is horribly expensive.
"What if?" addict
overscan
Testing a modification to place user avatars on index pages. Thoughts?
"What if?" addict
Quote from: overscan on July 23, 2016, 02:52:25 AM
set up new Avatar and can see it in action, like it  :thumbsup:
