avatar_Joe C-P
De Havilland Sea Venom
Started by Joe C-P, September 29, 2016, 12:26:32 PM
Looks good, i like dark schemes. :thumbsup:
Cool.
I investigated a piston engined Vampire.  Trouble is they ride so low you need loooooooong legs to get the prop clearance.
Quote from: zenrat on January 23, 2017, 01:32:00 AM
Which means the main leg pivot points have to move further outboard, and the nose leg needs a longer bay etc. etc. You end up re-designing the whole airframe.  :banghead:
Quote from: PR19_Kit on January 23, 2017, 01:49:26 AM
In which case you might as well make it a gull wing.
Librarian
Quote from: zenrat on January 23, 2017, 02:19:03 AM
...which would look fantastic :wub:
I remember reading that the gull wing reduced drag...was this on piston aircraft only or would it have been effective on jets too. If so, why so few gull wing aircraft?
I can't see why it would do so having the same or similar frontal area as a straight wing.
Although my theory of aerodynamics is based here on what early hot rodders did to go faster on dry lake beds and therefore is probably wrong.
Isn't it strictly speaking an inverted gull wing if its like a Stuka and Corsair?  A gull wing being if its like a Beriev flying boat.
Librarian
Whoops...my bad! Inverted it is :thumbsup:
I suppose there's just a chance that a wing that joins to the fuselage effectively at a right angle, as does the Corsair's, might have less drag than one that needs to be heavily faired in, as with a Spitfire etc.
I have my doubts that there's much effect, but you never know.
That's why most airliners have their wings attached to a fuselage box Kit, so the wing is attached perpendicular to a surface which eliminates massive root fairings
Quote from: kitnut617 on January 24, 2017, 10:43:23 AM
Inverted gull wings would look a lot better.  ;D
Mmmmmmmmm, inverted gull wing A380...
Quote from: zenrat on January 25, 2017, 01:06:40 AM
Why not?  It would blow all of the circuits in the average JMN brain!!
Quote from: Rheged on January 25, 2017, 01:49:39 AM
For some reason I've got two Beluga kits in The Loft.............  ;D ;)
steelpillow
Mmm, all that Airbus airliner talk reminds me that the DH Swallow was originally an aerodynamic scale model of the early tailless swept Comet proposal. Gull-winged Airbus don't need no stinkin' tail!
Rowing back a bit, a Sea Vixen with a low-set inverted gull wing and Merlin-powered ducted contra-fan would not need longer legs. I'd have said Griffon only its driveshaft is lower. Ah, well, maybe next time.
Cheers.
